Detailed write up.... HOW TO DO A Coil On Plug CONVERSION
Old Sep 8, 2005 | 02:11 PM
  #101
3gteg96's Avatar
Default Re: Detailed write up.... HOW TO DO A COP CONVERSION (kcevo)
So it wont throw any codes...And i jsut need one sensor...Cause my car needs a new distrb so i can really use that....Im going to end up getting a 4 channel MSD box..Where can i get the switch so i only need to hook up the one sensor/switch
Old Sep 8, 2005 | 02:39 PM
  #102
DaveF's Avatar
Default Re: Detailed write up.... HOW TO DO A COP CONVERSION (3gteg96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3gteg96 &raquo;</TD></TR><TR><TD CLASS="quote">So it wont throw any codes...And i jsut need one sensor...Cause my car needs a new distrb so i can really use that....Im going to end up getting a 4 channel MSD box..Where can i get the switch so i only need to hook up the one sensor/switch</TD></TR></TABLE>
are you running a honda ecu or do you have an aftermarket standalone? with more than 1 coil output??????
Old Sep 8, 2005 | 03:47 PM
  #103
3gteg96's Avatar
Default Re: Detailed write up.... HOW TO DO A COP CONVERSION (Dturbocivic)
I have a stock ECU...How would i set it up where i can run 4 CBR coilpacks..And get rid fo the Distrb...Ant having it run right, it hought u had to have the distrb to make it run right..But if there is a way around it let me know id like to do a msd box with the 4 coil outputs, and the 4 CBR coils
Old Sep 8, 2005 | 04:10 PM
  #104
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3gteg96 &raquo;</TD></TR><TR><TD CLASS="quote">I have a stock ECU...How would i set it up where i can run 4 CBR coilpacks..And get rid fo the Distrb...</TD></TR></TABLE>\
you cant.
Old Sep 11, 2005 | 08:26 PM
  #105
Ef88Lsvtec's Avatar
Great Writeup
Old Sep 14, 2005 | 09:36 AM
  #106
GimpyAccord's Avatar
Default Re: (Ef88Lsvtec)
Coming from the DSM world mostly, those motorcycle coil 'sticks' are pretty much universally seen as crap (due to dwell). COP setups on a DSM's are mostly 'for show' and usually the high HP cars are running stock OEM DSM packs/wires. Just something to consider before investing a lot of time into a coil stick setup.
Old Sep 14, 2005 | 09:45 AM
  #107
tony1's Avatar
Default Re: (GimpyAccord)
With a CDI system, the box holds the charge, so there is no dwell at the coil. I've run the CBR coil sticks up to 670whp so far with absolutely no ign. problems. Tell me this graph isn't smooth? Motec 4 channel ignition box (made by M&W) and CBR coils. Denso IK24 plugs at factory gap (around .030" i think)
Old Sep 14, 2005 | 09:54 AM
  #108
Default Re: (tony1)
I will forward this thread to a couple people on NABR who have discussed the coil sticks, as I don't have the technical prowess on that issue. I don't like to just parrot stuff I hear either. Hopefully they'll bring some insight/discussion to this.
Old Sep 14, 2005 | 09:56 AM
  #109
tony1's Avatar
Old Sep 14, 2005 | 10:36 AM
  #110
93LSivic's Avatar
Default Re: (tony1)
Looks good Tony. At what point would you run into using the IK27's. Are'nt the 24's equivilent to only a ngk 7 plug?
Old Sep 14, 2005 | 10:39 AM
  #111
tony1's Avatar
Default Re: (93LSivic)
Yeah, i don't think the 24's are very cold, but i've been keeping a close eye on them and they look fine. I told allen to get the coldest he could find and this is what he showed up with. lol
Old Sep 14, 2005 | 10:55 AM
  #112
Boostfed's Avatar
New User
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, i don't think the 24's are very cold, but i've been keeping a close eye on them and they look fine. I told allen to get the coldest he could find and this is what he showed up with. lol </TD></TR></TABLE>
HEHE cuz I got a few sets of IK31s for mine Good to know the CBR coils are good and even a hotter plug lik ethe IK24s worked well.
Old Sep 14, 2005 | 07:29 PM
  #113
Default Re: (tony1)
After getting schooled about the differences between a stock DSM inductive ignition, and a CDI setup I now understand why the dwell is not an issue. Party with the CBR coils
Sorry about the post!
Old Sep 14, 2005 | 07:41 PM
  #114
tony1's Avatar
Old Sep 20, 2005 | 04:48 PM
  #115
HondaIntegraR's Avatar
Default Re: (tony1)
just wondering, will cbr 929 coils work w/ rocket spark plugs?
Old Sep 20, 2005 | 05:49 PM
  #116
D-tuned's Avatar
Default Re: (HondaIntegraR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaIntegraR &raquo;</TD></TR><TR><TD CLASS="quote">just wondering, will cbr 929 coils work w/ rocket spark plugs?</TD></TR></TABLE>
you can if the the cap is threaded. if its not you can not use them
Old Sep 20, 2005 | 10:34 PM
  #117
JDogg's Avatar
Default Re: (D-tuned)
the denso coil sticks are very sensitive to dwell, thus they do not work well with an inductive ignition system. they are much better when paired with a CDI system. i have done extensive testing with the cbr coils and an inductive ignition for a budget setup.. go a hair over on dwell and you'll blow the tops off the coils and smoke the ignitor.
Old Sep 21, 2005 | 09:26 AM
  #118
Default Re: (JDogg)
what spark plug would you guys reccomend with 929 coils on an all motor setup?
Old Sep 21, 2005 | 11:14 AM
  #119
D-tuned's Avatar
I use bosh plugs for a 00 VW GTI. there heat range 8, cheap and I have never had a problem with them. i've used them and put down over 400whp no problem. next week I'm going to see if they can handle 500whp+
Old Sep 26, 2005 | 05:54 AM
  #120
cinq's Avatar
Default Re: Detailed write up.... HOW TO DO A COP CONVERSION (D-tuned)
You guys are bunch of hardcores.
Old Sep 28, 2005 | 02:07 AM
  #121
thermal's Avatar
D, good **** man. Still nuclear science to me. I guess I'm gonna have to get explain this **** to me when you help me install the rest of my crap.... ha ha ha...
Old Sep 29, 2005 | 04:24 PM
  #122
MrParks's Avatar
nice
Old Oct 2, 2005 | 06:54 PM
  #123
Rage Cayman's Avatar
Default Re: Detailed write up.... HOW TO DO A COP CONVERSION (GHOSTWORKS)
Using a Hall-effect sensor should be the way to instead of a magnetic sensor....
A magnetic sensor uses a permanent magnet sourounded by a coil of wire. The knotches of the crankshaft ( or camshaft) creates a variable magnetic field strength around the coil. When a metallic section is close to the sensor, the magnetic field gets stronger because metal is a better conductor of magnetic lines of force than air.
How does Hall-effect sensor work?
It requires a small input voltage to generate an output signal. Hall-effect is the ability to generate a voltage signal in semiconductor material by passing current through it in one direction and applying a magnetic field to it at a RIGHT ANGLE to its surface.
I dont know how to post a pictire to show an illustration of both sensors and why I think that the Hall-effect works the best.
Old Oct 15, 2005 | 08:49 PM
  #124
RMS's Avatar
RMS
nissan cam sensor is an optical sensor... not that it counts for anything
929 coils can be used on H22s without moding the valve cover with the added benifit of NGK plugs being useable in stock form. the cost is 35$.
Old Oct 17, 2005 | 07:34 AM
  #125
SQ is the SQUAD's Avatar
Default Re: (RMS)
i been trying to thjink up a setup like this for a while but gave up until i finish building the motor. i am glad i found this thread, hopefully someone can help me out.
i am building a b20b motor with dual side draft carbs. i am not going to be running any type of ecu, this is not a street car. i have 2 sets of cbr coils, i have a msd sci ingition box. i dont want to use any type of distrubitor so i am going to need some type of cam position sensor to trigger the coils
basically i am hoping the use a 12v siginal to the msd box to shoot a coil signal that will be distributed at proper timing to each coil without using the distributor.
i already started rewiring the car with a hotrod wiring kit
any help or ideas will be apprieiated
