Denso Iridium For Boost?
Old Mar 12, 2003 | 09:04 PM
swpdb16's Avatar
Default Denso Iridium For Boost?
In my future set up im thinking of using the denso iridium plugs i bought about 2 months ago with msd 8.5mm distributor wires. Are these good cold plugs or does anyone recommend different ones. Thanks
Old Mar 12, 2003 | 09:09 PM
boosted hybrid's Avatar
Default Re: Denso Iridium For Boost? (swpdb16)
Sparkplug have heat ranges on them, without posting exactly what the head range is, we cant tell you what if the plug is cold enough. I have always used standard ngk's heat range 6 or 7 with no problems. I replace plugs every 5,000 miles so iridium one's will get expensive even though they last longer. Your better off with standard ngk plugs: cheaper, easiest to get and will make the same power.
VaporTrail's Avatar
New User
I recommend OEM wires always. Nothing fits as good or works as well. I'll put an OEM wire up against anything.
For the plugs, the NGK iridium plugs are of better quality and they are cheaper as well. I can get them for about 7bucks a plug. I highly recommend them. We have a 450+hp SR running on the same plugs for almost a year now. Proof enough for me!
[Modified by VaporTrail, 1:10 AM 3/13/2003]
Old Mar 12, 2003 | 09:16 PM
earl's Avatar
Go with Denso IK27 or IK31. They are plenty cold.
Old Mar 12, 2003 | 09:48 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: Denso Iridium For Boost? (earl)
I dont like the iridiums myself. I have seen the ground strap break on them 2 times on a wrx and destroy the motor. I like the 1.52 a plug ngk 7's and 8's. especially since i change mine weekly on my street car.
digitalvice
17
Mar 25, 2013 03:14 PM
central_driver
Feb 5, 2006 09:37 AM
wreckedmyteg
Jan 25, 2005 02:03 PM
fw190bvi
Dec 11, 2003 07:08 PM
Brandon
Jun 17, 2002 07:25 PM
