Delphi 1000 cc injector question
Old May 15, 2013 | 07:12 PM
nenetech's Avatar
Default Delphi 1000 cc injector question
wats up HT been searcing through out the forum for info on the delphi 1000 cc injectors but only coming accross forsale threads i took it as an answer and figured they arent used often .. has anyone had any experience good bad ?? any opinions besides get id injectors or precision ??.. came accross a set for a ridiculous cheap price for barely no use .. and idk how much are they worth.. or if even are good for b series turbo charge applicaiton .. anyone care to help
Old May 15, 2013 | 07:54 PM
TheShodan's Avatar
Moderator
Default Re: Delphi 1000 cc injector question
Getting Precision over your Delphi's is a waste of time, because they are one in the same. Those are a Rochester/Lucas injector that has completely different pulse widths and millisecond time delays. They work for higher hp applications, but give people trouble for those that just want 400whp-600whp, unlike the Bosch-style injectors. They cause a lot of fuel pooling in the combustion chamber which makes tuning very difficult for lower levels.
So, use them if you must, but they will not behave anything like the Bosch or even Siemen Deka.
Old May 15, 2013 | 08:03 PM
nenetech's Avatar
thank you shodan i appreciate the feed back.. i guess im gonna be a bit more patience since my hp goal will be @ 400 if possible so maybe getting ids might be better just thought a buck and half was a good deal for faily new ones .. plus i didnt know if the mounted to my b series stock rail or if need different wiring
uvamosk
Sep 11, 2011 06:05 AM
X2BOARD
Jul 8, 2004 11:22 AM
B18C1_T
Aug 13, 2003 01:27 PM
kaneda3
Dec 30, 2002 12:18 PM
