Defi EGT Guage Sensor Install Location?
Old 03-02-2003, 01:11 PM
integra-modder's Avatar
Default Defi EGT Guage Sensor Install Location?
where should I install it on a inline pro manifold like the one pictures above?
I was thinking either #1 cylinder or between WG and turbo from the radiator side.
Thanks
Old 03-02-2003, 01:14 PM
B18Flip's Avatar
Default Re: Defi EGT Guage Sensor Install Location? (integra-modder)
I'm pretty sure most people say to use the #3 runner
Old 03-02-2003, 03:34 PM
LJR-LUDE01's Avatar
Default Re: Defi EGT Guage Sensor Install Location? (B18Flip)
what he said... I'm doing mine sometime next month take pic when you do it..
Old 03-02-2003, 03:55 PM
B18Flip's Avatar
Default Re: Defi EGT Guage Sensor Install Location? (LJR-LUDE01)
What size bit do you need to drill the hole for the defi probe? I have the same one
Old 03-03-2003, 03:01 AM
3/64 probably, and then run the thread out
anyone have a picture of their inline pro unit with a EGT sensor?
Old 03-03-2003, 05:18 AM
mskibbz-T's Avatar
Old 03-03-2003, 07:18 AM
Old 03-03-2003, 07:32 PM
anyone?
EGT sensor in a manifold pic?
Old 03-03-2003, 07:58 PM
TurbothisLS's Avatar
the defi gauges are the ish
sooo nice
Old 03-03-2003, 08:45 PM
B18EG6's Avatar
I didnt tap my mani...I used the hole for an internal wastegate on the downpipe...want a pic of that?
Old 03-03-2003, 09:42 PM
V-SPEC 1's Avatar
Default Re: Defi EGT Guage Sensor Install Location? (B18EG6)
yes please.
Old 03-03-2003, 11:11 PM
Dee
Dee's Avatar
Default Re: Defi EGT Guage Sensor Install Location? (boostedb20vtec)
My used 4 bolt ex housing came with two holes tapped in it. This is JDM style. All of my RX-7 and Skyline buddies run the same setup.
Old 03-04-2003, 02:52 AM
Default Re: Defi EGT Guage Sensor Install Location? (Dee)
i get an X? is the server down or is it a bad link?
Old 03-04-2003, 02:53 AM
yes sir
Old 03-04-2003, 06:05 AM
MachAF's Avatar
tap size should be: 1/8npt-27 thread pitch
Same and greddy egt.
Old 03-04-2003, 05:42 PM
Default Re: Defi EGT Guage Sensor Install Location? (machaf)
ok, anyone have a picture of it being done to the manifold or should i do it to the at the trubo??
Old 03-04-2003, 05:51 PM
Cramerox's Avatar
Do it on the Manifold 3rd runner about 1inch to inch and half away from the flange. Also good idea to mount the WG so you have a good idea how much area the Sensor sill need. You might tap to close to the WG.
Old 03-05-2003, 07:06 AM
Default Re: Defi EGT Guage Sensor Install Location? (Cramerox)
which is the third runner? and do you mean 1.5 inches away from the block or from the turbo?
Old 03-05-2003, 12:23 PM
Cramerox's Avatar
Third runner is the runner second from the left. and i say 1.5inches from the block or the flange from the block is fine.
xDicktonesx
05-15-2005 12:12 PM
Sohc Driver
06-09-2004 07:05 PM
FredoSP
01-02-2004 03:44 PM
Turbo(less)DB8
05-12-2003 07:06 PM
fuguman
08-02-2002 01:58 PM
Quick Reply: Defi EGT Guage Sensor Install Location?
