Defi Display and Boost
Old Apr 16, 2006 | 11:11 AM
a1320addict's Avatar
Default Defi Display and Boost
I'm looking for someone experienced with the Defi Link Display system.
Defi mentions on their site that the Link-Display can show boost, but I haven't found the sensor set for it.
Will the display show boost like it does for oil temp, oil pressure, water temp etc?
Also, anyone who is using it, how did you go about setting everything up. Where did you tap for the water temp, and what can you suggest for the oil temp besides a sandwich plate...my golden eagle is already hooked to my oil pressure and oil feed.
Thanks
Old Apr 16, 2006 | 11:50 AM
Default Re: Defi Display and Boost (yehiknowrite)
up
Old Apr 16, 2006 | 12:03 PM
Boilermaker1's Avatar
the display will not show boost, you can use the display to program the warning though.
You still need a dial boost guage to show it.
If there's a way to make the display show boost, I haven't found it in the menus, and the instruction pamphlet doesn't show it.
Oil pressure is tapped into the drain bolt, oil pressure at the remote filter exit, water temp is in a fitting I made for the rad. hose, boost is tapped into the brake master vac.
Old Apr 16, 2006 | 12:04 PM
Default Re: (Boilermaker1)
Thanks for the response.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yehiknowrite &raquo;</TD></TR><TR><TD CLASS="quote">how did you go about setting everything up. Where did you tap for the water temp, and what can you suggest for the oil temp besides a sandwich plate...my golden eagle is already hooked to my oil pressure and oil feed.
no bull
Oct 2, 2007 11:34 AM
eboixing
Aug 28, 2007 11:55 AM
s13freeaak
Jun 5, 2006 07:07 PM
1.8T_EG
Jul 20, 2003 03:15 PM
Boostless97Lude
Jun 18, 2003 08:42 AM
