Decking a stock block???
Old May 24, 2008 | 07:28 AM
RACEPAK's Avatar
Default Decking a stock block???
sup.
should i deck a stock d16 block for 400hp?
srp 75.25 9.1:1
and how much
thanks
Old May 24, 2008 | 07:38 AM
yakuza's Avatar
Default Re: Decking a stock block??? (RACEPAK)
You don't state what are your other mods so its hard to tell, but goin by that compression ratio you have I'd say no, unless the head is not even and need machining ..
Old May 24, 2008 | 07:42 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: Decking a stock block??? (yakuza)
anytime you build a motor you should deck the block and head so you have an even mating surface
Old May 24, 2008 | 08:16 PM
HiProfile's Avatar
Default Re: Decking a stock block??? (EARLdaSQUIRREL)
People have made 400whp on SOHC's with 8.4:1 Wiseco and Vitara pistons, so I'd have to say no. If you were running 100+ octane, it wouldn't be a bad idea, since each PSI will make a little more power if it was higher compression.
Old May 24, 2008 | 10:17 PM
blinx9900's Avatar
Default Re: Decking a stock block??? (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">People have made 400whp on SOHC's with 8.4:1 Wiseco and Vitara pistons, so I'd have to say no. If you were running 100+ octane, it wouldn't be a bad idea, since each PSI will make a little more power if it was higher compression.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yakuza &raquo;</TD></TR><TR><TD CLASS="quote">You don't state what are your other mods so its hard to tell, but goin by that compression ratio you have I'd say no, unless the head is not even and need machining ..</TD></TR></TABLE>
what does psi and compression have to do with decking the block?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EARLdaSQUIRREL &raquo;</TD></TR><TR><TD CLASS="quote">anytime you build a motor you should deck the block and head so you have an even mating surface </TD></TR></TABLE>
agreed. i dont care what psi, fuel, compression the engine has, if your building it deck the damn block and eliminate the possilbity of a poor hg seal.
Old May 24, 2008 | 11:03 PM
yakuza's Avatar
Think what some of us is saying, as long you decking/resurfacing the head/block to make it even that is fine but do not take some of it to increase the compression rate.
I went 8:2:1 but then got my machine shop to take 0.5mm of the head to raise the compression up again.
civicjoe
Apr 7, 2008 11:04 AM
dek1mfk
Jun 22, 2007 10:47 AM
Mugencrxsir1
Mar 2, 2006 04:55 PM
tobe1424
Sep 1, 2005 11:00 AM
BeavisB16
Feb 22, 2003 12:28 PM
