Deburring piston ring.
Old 03-16-2005, 07:29 PM
MidShipCivic's Avatar
Default Deburring piston ring.
What do I use to deburr the end of the piston ring I just filed?
Old 03-16-2005, 07:48 PM
Bailhatch's Avatar
Default Re: Deburring piston ring. (MidShipCivic)
i used 400 grit sandpaper
Old 03-16-2005, 08:17 PM
Default Re: Deburring piston ring. (Bailhatch)
Thanks for the info any more advice? Like how to do it (technique) .
Old 03-16-2005, 08:24 PM
Blang's Avatar
Make sure you sand, or if you use a fine file, to stroke verrrry lightly and to stroke away from the gap.
Old 03-16-2005, 08:28 PM
Default Re: Deburring piston ring. (Blang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blang &raquo;</TD></TR><TR><TD CLASS="quote">Make sure you sand, or if you use a fine file, to stroke verrrry lightly and to stroke away from the gap.</TD></TR></TABLE>
Thanks #1st time poster welcome to H-T.
Old 03-16-2005, 08:36 PM
Bailhatch's Avatar
here's where i got the idea. I went over all the edges of my rings as well with 400 but i didn't use a scuff pad to remove any coating like this guy. http://www.circletrack.com/howto/4639/
Old 03-16-2005, 08:57 PM
Great link, thanks for your time Bailhatch .
Old 03-16-2005, 10:41 PM
earl's Avatar
I use a very fine knife sharpening stone. Just hit the edges
Old 03-16-2005, 10:49 PM
Default Re: Deburring piston ring. (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">I use a very fine knife sharpening stone. Just hit the edges</TD></TR></TABLE>
Thanks for the advice. Interesting tool for the job .
Old 03-17-2005, 05:41 AM
earl's Avatar
In the old days, engine builders used to use large stones to smooth out the surface of the rings to achieve a better seal between the ring and the piston ring land. Now days rings are much flatter from the manufacturer.
Old 03-17-2005, 09:21 PM
Bailhatch's Avatar
The sharpening stone sounds like it would be easier to use than the sandpaper. good idea One of those little stones, like 1" x 4" x 1/4", would be perfect I bet.
Old 03-17-2005, 09:33 PM
earl's Avatar
That is what I use, works good for me
imadigitalgod
Audio / Security / Video
12-26-2009 10:27 PM
Flr Power
07-13-2005 05:07 PM
SixguN
07-09-2005 05:13 PM
Ek-CoolGuy
01-30-2003 06:19 AM
Quick Reply: Deburring piston ring.
