debating
got a good deal for a b16a goin on right now..thing is there real high comp and i wanna go boost but i dont have the time to rip every thing apart and rebuild..so i was wondering how many pounds can i run on it stock and for a daily?
thinkin t3/t4 57 trim..little setup..maybe 7-8 ibs..y the b16..becuz i have a good deal on it..every thing i need to swap in the car..i personly kno it runs good cuz hes a good friend of mine..but he wrecked the sol so hes selling everything and getting out of the game..i have z6 in the coupe right now and spare block and head and somother parts for it cuz i was gonna start building a z6 turbo setup but im leaning towards this b16 and selling all the z6 stuff prolly..idk..soo swap b16 in and build the d on the side or put the b in and do what was said to it and just sell every thing d sereis i got
If you plan on boosting it....I'd say it would be alot easier to upgrade the internals now...it will be ALOT less work in the long wrong.
Sell your spare D series parts to make some money...get the internals fixed up on the B before you put it in...and then work on your boost goals from there. Alot of people start out just saying oh yeah just a little bit of boost...then they get the itch because they know how much they COULD have with just a little bit more work.
Upgrade the internals before you put it in if you plan on doing it down the road at all...just my .02
Set a power goal. There are plenty of people making good power on stock B16 bottom ends. I would say get the swap in and driving and then start selling your Dseries junk while collecting Bseries turbo parts and researching.
stock b16a2 here t3/t4 57 trim .63 ar....325 hp at 11 psi for a year, bumped it up to 17psi for the past year with boost by gear...motor is still strong no issues. do a leakdown and compression test to make sure it a healthy motor.
For 250whp, guesstimated that would be 275-280ish to the crank.... 7-9lbs should do the trick. But as someone else already stated, slap that B16 in there, sell your D series stuff and buy up the turbo set up... and save up for the internals. A stock B16 shouldn't have any trouble handling 6-8psi (daily driven), but if you want to go higher on boost, I would suggest getting internals done....... and everyone... EVERYONE always wants more boooooooooost. lol
...still...if you feel like later down the road you might want to go higher and the funds are available it would be easier to do it before you put it in...best of luck with all of this
roofernick
17
Jan 7, 2011 09:48 AM
apouan620
Jan 10, 2006 03:39 PM
luckecharm2004
Nov 10, 2004 05:15 PM
