Dealing with wheelspin in a turbo car?!?!?
Old Aug 23, 2007 | 11:16 AM
blackhope121's Avatar
Default Dealing with wheelspin in a turbo car?!?!?
This is my first turbo car. Ive never really had a fast car before now so im not used to the wheels breaking loose in the middle of the gear.
1st and 2nd the wheels spin when i hit full boost.
Honestly honda-tech.. honestly.....should i let it bounce of the rev limiter a couple times and then shift? My tuner set the new rev lmiter at 7600.
Old Aug 23, 2007 | 11:32 AM
sp00led's Avatar
Default Re: Dealing with wheelspin in a turbo car?!?!? (blackhope121)
Get stickier tires (i.e. drag radials) or turn down the boost in 1st and 2nd gear.
Old Aug 23, 2007 | 12:06 PM
Lonnie's Avatar
Get a boost controller thats gear dependent
Old Aug 23, 2007 | 04:16 PM
Schister66's Avatar
Man U FTW
i run drag radials all the time on my 315whp turbo GSR....its the only way to roll
Old Aug 23, 2007 | 04:26 PM
iBrandon's Avatar
Default Re: (Schister66)
Need tires like mine! no spinning!
Old Aug 23, 2007 | 04:33 PM
Mr HYDE's Avatar
Default Re: (iBrandon)
you learn real fast how to shift a turbo honda, at least i did. i got stickier tires but at 650whp it spun hard either way.
Old Aug 23, 2007 | 04:59 PM
CRX T-Si's Avatar
Default Re: (Mr HYDE)
Once you realize how much your tires will cost you will learn to feather it to control it...in due time you will learn.
Old Aug 23, 2007 | 05:07 PM
tokesGTR's Avatar
Default Re: (CRX T-Si)
It's all about throttle modulation. Try not to ride the rev limiter, you'll get the hang of it
Old Aug 23, 2007 | 05:09 PM
Default Re: Dealing with wheelspin in a turbo car?!?!? (Lonnie)
Thanks for the replies everyone
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lonnie &raquo;</TD></TR><TR><TD CLASS="quote">Get a boost controller thats gear dependent</TD></TR></TABLE>
Is there away to adjust it with crome?
Old Aug 23, 2007 | 05:25 PM
bootlegcivic's Avatar
You really don't need drag radials they are expensive and don't handle very well(on the street), plus they wear out really fast. I run general Exclaims on my 300whp setup with traction bars and a Apexi AVCR gear based boost controller (6psi in 1st, 8 for 2nd, then 10 for the rest). No spin unless you make it. My buddy drives daily on the same setup as mine but 428whp and has minimal spin. If you don't want to spend the money for an AVCR you could do a TurboXS dual stage. I don't know if your ecu program will tie into it but I know Neptune does.
Old Aug 23, 2007 | 06:39 PM
WHTZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si &raquo;</TD></TR><TR><TD CLASS="quote">Once you realize how much your tires will cost you will learn to feather it to control it...in due time you will learn.</TD></TR></TABLE>
Excatly! BTW I hate driving on 225's!
EG_SINZ
May 22, 2011 10:20 AM
umair
Oct 30, 2010 07:01 AM
wattsdc2turbo
Apr 14, 2010 03:25 PM
LSTDB8
Aug 2, 2007 05:37 PM
