dc2 resistor box install
Old Mar 9, 2004 | 09:00 PM
whackassfawker's Avatar
Default Resistor box install. I could use a little advice.
My car is a 98 integra and I followed the (Offical ht resistor box install). Anyways I looked on my car and I do not have a plug where all the wires terminate into. The wires are spliced through. I tested all the wires and found continuity through four of the wires leading to the yellow and black injector wires. The owner before me swaped back and forth between injectors by the way. Now my question is, does it matter if the plug is missing and you wire the four yellow and black injector wires to the various black wires on the resistor box. Then wiring the four that lead to the ecu to the red lead on the resistor box? Will this work? I could really use a hand here, because I cannot afford any more mishaps on this project.
Thanks so much.
Modified by Type R #0008 at 9:31 PM 3/10/2004
Old Mar 10, 2004 | 08:24 AM
bump. I need some advice.
Thanks
Old Mar 10, 2004 | 12:25 PM
bump
Old Mar 10, 2004 | 12:37 PM
Scott - 93HB Si's Avatar
Default Re: (Type R #0008)
your car is obd2, so the install doesn't work the same.
Basically what you need to do is connect each of the Yel/Blk wires off your injectors to the 4 inputs on the resistor box connector, then connect the single output of the resistor box to any of the injector Yel/blk lines that you cut going back to the wrie harness.
Old Mar 10, 2004 | 12:47 PM
does it matter if I connect all 4 wires to the red single lead on the resistor box and then one black for every injector. The car runs this way. It runs like **** because I have 680cc in it and haven't had the hondata set for them.
Old Mar 10, 2004 | 05:58 PM
anyone know if it matters that the clip is missing?
T-RO
Feb 9, 2014 07:06 AM
lsturboguy
Jun 4, 2007 09:33 AM
Dunc
Oct 2, 2005 02:12 PM
PLRacer
Jul 21, 2004 04:04 PM
Happyman
Aug 26, 2003 09:08 PM
