DaX's D16Z6 turbocharger build - older, but maybe not any wiser
#301
Re: DaX's D16Z6 turbocharger build - older, but maybe not any wiser
Thanks man! It's been fun to be older and have more money and patience this time around.
I probably didn't have something set right. It ran fine in open loop all day today, so I may leave it like that for now and mess with it over time, or just leave it like that until I have it tuned.
I got the power ran to the ethanol gauge tonight, so it lights up, but like the boost gauge, the sensor is not installed yet.
#302
Yes. Run it open until it's properly tuned. Closed loop can't really be run right out of the box now. Need settings such as the corrections and such. I don't have my laptop in front of me right now to go over Neptune stuff.. Anyways.. It needs tuning, good sir!
#306
So I've got my intake manifold (stock Z6) off to make room for getting all my fuel upgrades on, and to clean up some of the engine bay wiring. I'm thinking of tapping / plugging the unused ports on the intake manifold and throttle body. Anyone else done this? Here's what I'm thinking:
Thoughts?
- PCV nipple on intake manifold - cut off steel nipple, drill and tap for 1/8" NPT, plug it.
- Stock FPR nipple on intake manifold - I'm going to use the nipple that did go to the purge solenoid for the FPR since it will now be firewall mounted. For the old nipple, cut it off, drill / tap / plug, but what size? I don't think I can get a pipe tap that small. May just tap it one of the smaller metric screw sizes and plug it with a screw/bolt with loctite.
- Charcoal canister nipple on throttle body - this is before the throttle plate, so no issues driving around NA, but would be a boost leak once I'm turbo. Similar to #2, probably just cut it of, drill/tap/plug with M6x1.0 or something like that.
Thoughts?
#307
They sell rubber caps for those at the parts store.. Box of assorted size is about 5 or 6 bucks. I have used them with wonderful success!
#309
^ I bought a big assorted box of those rubber caps on eBay a few years ago to use specifically for plugging those random intake ports that are no longer needed. I usually put a small zip tie on them just to make sure they don't go anywhere.
#310
Not at all. As said below also, a small zip tie can help ease any lingering worry. The only concern is that you keep an eye on them for cracking over time. I noticed one day I had some slight idle hunting that got worse over a couple days and turns out I had a cracked port cap. Applied new cap, no more surge. Lol! Beats drilling and tapping any day!!
#311
^^Thanks for the suggestion on the caps, guys.
I've been working on the car the last couple of evenings. I had to get a buddy to weld an extension onto my FPR bracket so I could mount it here - the original holes in the bracket would have been right over where the wiper arm connects to the body and I couldn't have bolted through. I now have my flex fuel sensor where I want it and my braided return line from that to the stock hard line made. I'm waiting on my battery tray to be modified to add a mount for my fuel filter before I can finish plumbing the engine bay. Tonight I pulled the fuel pump hanger and installed the Walbro 450. I was going to build my own relay harness, but just broke down and bought the Burton Racing one - hope to start installing it tomorrow.
#312
Nice! That 450 is gonna sing you some sweet lullabies!!
#313
Very nice fuel system setup!
I just relayed my pump using a standard 30 amp relay from Oreillys.
#314
I got the Burton-Racing fuel pump harness mostly installed tonight - it's put together very well and I'm pretty happy with it. I wish there were somewhere else to ground the pump besides the bolt that holds the rear seat cushion down. I guess it's not too big of a deal, and the cushion stays down on its own for the most part. The rubber grommet that goes through the cover over the fuel pump is 25 years old and pretty stiff - there was no way I was getting the wires and plugs on the new harness through, so I had to split it, slide it around the wires, and tape it back up. I am keeping all the stuff under my dash, so the best place I came up with to mount the relay and fuse was on the SRS module cover. The relay is slightly visible in the passenger floorboard, but it's out of the way. I ran the wires under the carpet down beside the center tunnel and back to the fuel pump. I'm running all my wiring for my add-ons through the former cruise control cable hole in the firewall, and the harness has enough length to get to the positive battery terminal.
I also got my hard line in the engine bay cut off and the -6AN union installed.
#315
Go go go!!! Coming out good. You have much more patience than I do for wiring. Lol!
#316
#317
Progress is looking great. I too just installed the Burton fuel pump kit this weekend, was very very pleased with how easy it was to install! Not to mention the immediate improvements it made. Excited to see this coming together!
#319
Gonna look butter smooth with that x500 kit! You planning on an intake mani at all? I almost forgotten how small the stocker is vs the S2. Lol!
#321
Thanks for the props, and for the parts!
Thanks!
#322
So, I get not running the coolant lines to the IACV - no big deal, but will the FITV still function correctly without coolant lines? I mean, isn't the whole purpose of the FITV to allow fast idle until the coolant warms up, then it drops the idle to normal? I just don't see how that would work without coolant lines, but I sure would like to delete that line for a slightly cleaner looking bay.
#323
#324
DaX, in colder weather, the lack of fluid flow to the FITV wax plate will SLOW the transition from a higher idle to the normal operating temperature idle speed, but ultimately, the aluminum gets hot enough through transfer to do the same thing as the coolant does. During the warmer times of the year... you probably won't even notice the difference.
