Darton Sleeves?
Old Jun 22, 2003 | 09:54 AM
RudeLude's Avatar
Default Darton Sleeves?
i read somewhere that darton has replacement sleeves that will hold like 15-16 psi, and theyre like a direct replacement, anyone ever heard or know about these? theyre supposed to be like $40 a sleeve, and theyre the same ductile iron as their performance sleeves. does anyone know about these, and what do u know?
daniel
Old Jun 22, 2003 | 12:53 PM
E Swift's Avatar
Default Re: Darton Sleeves? (RudeLude)
never heard of that.
Old Jun 22, 2003 | 01:02 PM
GraphiteAccord's Avatar
http://autoraceparts.com/
Old Jun 22, 2003 | 01:46 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: Darton Sleeves? (GraphiteAccord)
yeah, they are like the darton juniors. i have seen 30psi thru those also by the way and they held up fine. they just arent closed deck or the same thickness. we use the auto race sleeves in our h22 race car and made 689 whp.
Old Jun 22, 2003 | 03:23 PM
RudeLude's Avatar
Default Re: Darton Sleeves? (MotorMatrix.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MotorMatrix.com &raquo;</TD></TR><TR><TD CLASS="quote">yeah, they are like the darton juniors. i have seen 30psi thru those also by the way and they held up fine. they just arent closed deck or the same thickness. we use the auto race sleeves in our h22 race car and made 689 whp.</TD></TR></TABLE>
thanks man, i knew someone here would know about them. anyways, where can i find them, and with my motor being closed deck already, do u think i'll be good with about 15-18 psi on a tuned built h22a?
thanks again for the help
daniel
Old Jun 22, 2003 | 03:25 PM
I am a bad person
on a closed deck block a sleeve is a sleeve to me. on an h22 you basically have an 1/8 inch solid ductile sleeve no matter who you use. we have boosted 30psi ont he autorace sleeves without any issue with the sleeve. the installationis another story . just make sure whoever installs them does it right and they will handle whatever you can throw at them.
Old Jun 22, 2003 | 05:38 PM
93LSivic's Avatar
I can have this done for you.
Basically just taking out the stock sleeve and re-installing the Darton sleeve which is the same ductile iron and a little thicker then stock.
Old Jun 22, 2003 | 08:16 PM
RudeLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MotorMatrix.com &raquo;</TD></TR><TR><TD CLASS="quote">on a closed deck block a sleeve is a sleeve to me. on an h22 you basically have an 1/8 inch solid ductile sleeve no matter who you use. we have boosted 30psi ont he autorace sleeves without any issue with the sleeve. the installationis another story . just make sure whoever installs them does it right and they will handle whatever you can throw at them.</TD></TR></TABLE>
ok, so does the block need to be machined to fit these, or are they direct replacement? thanks alot for the help.
daniel
Old Jun 22, 2003 | 08:44 PM
roydogg's Avatar
Default Re: Darton Sleeves? (93LSivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic &raquo;</TD></TR><TR><TD CLASS="quote">I can have this done for you.
So how much am I lookin at to replace me b18b stock sleeves with the darton sleeves? Total labor, parts, and time?
Old Jun 22, 2003 | 09:38 PM
93LSivic's Avatar
Default Re: Darton Sleeves? (roydogg)
I would suggest the closed deck sleeves for any open deck honda.....or your block basically.
Prices are up there, but more than worth it. PM me for prices.
Old Jun 23, 2003 | 11:34 AM
RudeLude's Avatar
well thanks for the help guys, if theres any more info keep it coming.
daniel
Old Jul 1, 2003 | 05:05 PM
RudeLude's Avatar
Default Re: (RudeLude)
has anyone used the darton flanged sleeves, or should i just go with the autorace?
thanks again guys.
daniel
Apr 11, 2008 08:23 PM
shad0wslay3r
61
May 16, 2007 12:30 PM
JDMRice
Jan 30, 2007 11:35 PM
hookups214
Oct 14, 2005 07:23 AM
Rick Solis
Apr 14, 2004 01:51 PM
