Damn CEL!!! Help!
Old Aug 13, 2002 | 04:09 PM
zojirushi's Avatar
Default Damn CEL!!! Help!
Ok, been boosting for about 2 weeks. No big problems yet. Lately i've been getting CEL's after i boost. But after i turn the car off and back on, the CEL is gone. Dammit, how do i check the CEL if it keeps dissappearing. Ok, before i turn it off, the car feels really sluggish, and at idle, its really shitty. I'm using rc 370's and my idle fuel pressure is at 50 psi. I use the s-afc hack and set my numbers -45% across the whole thing. I've tried setting it at -40%, same ****. CEL comes on. Help anyone!
Old Aug 13, 2002 | 04:37 PM
zojirushi's Avatar
Default Re: Damn CEL!!! Help! (zojirushi)
Ok, i just pulled my plugs, and they are BLACK! They are zfr7f-11. I just swapped in zfr6f-11's. Any idea folks?
Old Aug 13, 2002 | 04:39 PM
dustin's Avatar
I bet it's a MAP code. What boost level?
Old Aug 13, 2002 | 04:45 PM
zojirushi's Avatar
Default Re: Damn CEL!!! Help! (dustin)
.5 bar
Can spark plugs ever cause a CEL?
[Modified by zojirushi, 8:45 PM 8/13/2002]
Old Aug 13, 2002 | 04:54 PM
bmm89's Avatar
lower fuel pressure and a missing link...
Old Aug 13, 2002 | 04:57 PM
zojirushi's Avatar
Default Re: Damn CEL!!! Help! (bmm89)
then i wouldn't be using the s-afc hack, and would need an fmu and inline pump.
Old Aug 13, 2002 | 05:47 PM
Evil DOHC's Avatar
Ditto, thats your problem kid.
Give me a call on the weekend, if you want me to take a look at it.
EVIL
Old Aug 13, 2002 | 07:46 PM
ion_four's Avatar
Default Re: Damn CEL!!! Help! (Evil GS-R)
EVIL
I don't agree. if he uses the missing link it will totally tweak his set-up because the afc won't be intercepting the boosted MAP signal and changing it.
Old Aug 13, 2002 | 07:51 PM
zojirushi's Avatar
Default Re: Damn CEL!!! Help! (ion_four)
I'm kinda leaning towards my o2 sensor. What exactly would a busted o2 sensor do to your car?
Old Aug 13, 2002 | 08:01 PM
filetofit
Guest
Posts: n/a
Bad o2 = poor gas mileage, running rich if your ECU goes into limp mode.
Old Aug 13, 2002 | 08:31 PM
dustin's Avatar
Default Re: Damn CEL!!! Help! (filetofit)
This is happening after boosting, people. I guarantee you it is a MAP code.
Old Aug 13, 2002 | 09:38 PM
zojirushi's Avatar
but i'm trimming the signal alot with the afc. I don't see how its possible unless my s-afc is broken. And also, it doesn't happen right after boosting.
[Modified by zojirushi, 1:39 AM 8/14/2002]
Old Aug 14, 2002 | 08:04 AM
zojirushi's Avatar
update:
ok, this seems to happen upon deceleration.
Also, this problem has seem to started after i developed a exhaust leak after the downpipe, near the o2 sensor.
Old Aug 14, 2002 | 08:22 AM
DSF's Avatar
DSF
Pull your codes first. I don't know about the teg, but my Civic cas a blue "service connector" under the passenger side dash, by the kick panel above the ecu. Jump this connector with a piece of wire and turn the ignition to "on" (don't start the car). Then count the flashes of the CEL for the code number....
Old Aug 14, 2002 | 09:13 AM
zojirushi's Avatar
Default Re: Damn CEL!!! Help! (DSF)
my cel goes away after i turn the car off... will i still be able to check the code?
Old Aug 14, 2002 | 09:25 AM
DSF's Avatar
DSF
Yes.
Old Aug 14, 2002 | 09:26 AM
filetofit
Guest
Posts: n/a
At idle you need a little more fuel, set that at -35% and leave the rest.
Old Aug 17, 2002 | 08:47 PM
zojirushi's Avatar
UPDATE: Ok, i've seemed to have fixed the problem. I just reset the ecu and now the cel doesn't come on anymore....
djtony5
Jul 29, 2005 12:45 AM
95ILS
Jun 21, 2005 09:13 PM
Johnny_Rocket
Mar 5, 2005 09:56 PM
cu3tip
Apr 10, 2004 11:28 PM
Skunk2_92gsr
Apr 2, 2003 06:55 PM
