jrsc help asap
Old Sep 29, 2003 | 10:58 AM
deez92's Avatar
Default jrsc help asap
can someone please tell me where i hook up the pcv hose to? i went hondata and have no clue where to hook it up at. can i just tee off where the break booster is? thanks dee
Old Sep 29, 2003 | 01:06 PM
GreddySi99's Avatar
Default Re: jrsc help asap (deez92)
go to jacksonracing.com and they will have the instructions there
Old Sep 29, 2003 | 03:56 PM
deez92's Avatar
Default Re: jrsc help asap (intercooledJRSC)
thanks but i still don't get it. anyone esle?
Old Sep 29, 2003 | 05:58 PM
keebler65's Avatar
if my memory serves me correctly, doesnt it connect to the barbed fitting on the bottom of the "S" tube? i know its in the instructions though if you look for it.
Old Sep 29, 2003 | 06:31 PM
Muckman's Avatar
Moderator in Chief
http://www.jacksonracing.com/m...0.pdf
Modified by Muckman at 9:15 AM 10/1/2003
Old Sep 29, 2003 | 06:54 PM
gitwidit's Avatar
Default Re: jrsc help asap (Muckman)
pcv hose goes to the black crank case vent breather box on the back of the block. you can try to fit your pcv valve into the box or just put it in-line between the intake manifold and box.
Old Sep 29, 2003 | 08:05 PM
deez92's Avatar
Default Re: jrsc help asap (GITWIDIT)
thanks for the help guys. i do know that one end of the hose goes in the black box. i'm having trouble trying to figure out where the other end goes. i know the stock location is the front of the intake manifold. thanks again guys dee
Old Sep 29, 2003 | 08:19 PM
keebler65's Avatar
go to the jackson site, download the type r instructions, then read steps #95-97 and it should clear it up for you if you still have questions.
crxt25turbo
Mar 28, 2024 12:07 PM
sageuvagony
Aug 14, 2008 10:29 AM
yostuhfoo
May 16, 2007 09:43 AM
Otherguy
Apr 13, 2005 05:41 PM
Luni420
Mar 4, 2005 11:00 PM
