d16z6 and td05hr expectations
I am currently building a z6 and am looking for anyhere from 275-325 hp, it gonna be my DD. I just picked up a evo 8 td05hr 16g for pretty cheap and was wondering what i can expect out of it? Would 17psi do the trick? anyways the plan is to buy an aftermarket evo 8twin scroll manifold, cutting the flange and wilding a z6 exhaust flange to make it work. Thanks
Re: d16z6 and td05hr expectations
not a build that is real common... if you are buying an aftermarket manifold, why not contact one of the sponsors on here and have them make something up for ... if you are getting a decent manifold anyway, by the time you finish cutting and making the evo one work, you'll probably be further ahead with a custom job....
good turbo, might take some work, but it'll be fun for you..
The z6 head is alot narrower then the 4g63 heads so youwill have to modify the runners starting just past the collector for it to work well. I cut them about 3ins from the flange and worked from there to bring them in. There are a few people who build manifolds and have made them for d and b series but make sure you merge the runners correctly so the twin scroll works.
streiche93
06-20-2015 01:16 PM
211811518
09-24-2006 03:33 PM
5speed4life
06-13-2005 09:03 PM
