D16Z6 swap Need help!
Old May 6, 2004 | 10:13 AM
Tyreece04's Avatar
Default D16Z6 swap Need help!
I have a 1998 Honda Civic Dx (D16Y7) and just got a d16z6 complete with everything but the ECU. Im getting the ECU for it and the skunk2 OBD2 to OBD1 conversion harness. The only problem im having is the wiring harness on that engine wont plug into the plug by the fender wall going to the ECU. There is only one plug on the stock wiring but my enigine harness on the D16Z6 has 2 on each side. If there is a conversion available for this or if anyone could let me no how to accomplish this i would really appreciate it.
Old May 6, 2004 | 10:28 AM
USDM 4G VTEC's Avatar
Default Re: D16Z6 swap Need help! (Tyreece04)
rule of swap
always use the harness off the stock car to run the engine
just use the harness off the engine u bought to obtain any xtra plugs u might need
Old May 6, 2004 | 01:14 PM
Tyreece04's Avatar
Default Re: D16Z6 swap Need help! (USDM 4G VTEC)
If i do that then how will i do the vtec part. My engine was not a vtec and dont no what to do about that
Old May 6, 2004 | 01:21 PM
warwagon's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyreece04 &raquo;</TD></TR><TR><TD CLASS="quote">If i do that then how will i do the vtec part. My engine was not a vtec and dont no what to do about that
you my friend need to take your car and drop it off... pay someone and pick it up running!!!
Old May 6, 2004 | 02:05 PM
mamaboy's Avatar
does ohio have the same rules as cali for the engine swap / obd rule? just wondering because if that would never pass smog requirements since your going from obd2 &gt; obd1...but if it's a race car who cares
Old May 6, 2004 | 04:29 PM
Tyreece04's Avatar
Default Re: D16Z6 swap Need help! (mamaboy)
yea ohio does have the same laws as cali. I cant bring it in anywhere because noone will do it because of that law
i jus need to no what i have to do to make the vtec work
Old May 6, 2004 | 04:38 PM
showtymers619's Avatar
* B A N N E D *
use your wireharness and do alot of research on here...
go to hybrid-honda.com they ahve alot of stuff there and cspeedracing
alot of how to stuff... basicly what you have to do is...
just wire the vtec stuff up yourself
Old May 10, 2004 | 04:04 PM
Tyreece04's Avatar
Default Re: D16Z6 swap Need help! (ShowTymers619)
I need to no if you can help me with engine wiring diagrams for the d16z6 and the d16y7. If you could help me out with this i would really appreciate it.
Old May 10, 2004 | 04:07 PM
5STAR3's Avatar
first off migrate over to the hybrid section....
then check this out, i think it is exactly what you are looking for.
www.d16z6-into-a-1998-civic-DX.com
Old May 10, 2004 | 04:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mamaboy &raquo;</TD></TR><TR><TD CLASS="quote">does ohio have the same rules as cali for the engine swap / obd rule? just wondering because if that would never pass smog requirements since your going from obd2 &gt; obd1...but if it's a race car who cares</TD></TR></TABLE>
well yes and no
supposely u need to have an engine that is same year or newer than ur car
but here on ohio , on inspections and e checks they dont check that ****
all they do is pull the car on rollers, check the vin number...... and pay ur $19
they dont check the emision hardware and or check all the codes and crrap... to many people 96+ run OBD1
as far as the harness question... u take the VTEC plugs off the vtec harness and add it to ur exhisting harness
jaggrieger30
Mar 5, 2007 03:17 AM
memorybox
Jul 4, 2006 10:06 AM
coreypoppej6
Apr 16, 2005 12:42 PM
scratchy
Jul 31, 2004 05:57 AM
SOHCEK-Turbo
Aug 12, 2003 01:41 PM
