Will OBD2B engine harness work with a d16z6? HELP
Yes, I did search and did not come up with an answer. I have a d16z6 engine and need it to run off of a obd2b engine harness with the p2p ecu. Is this possible? If not what codes will i throw. Can i just get a coversion harness and run a p28? I need to know what all is involved.
Thanks
Thanks
1 Post
Re: Will OBD2B engine harness work with a d16z6? HELP (jaggrieger30)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaggrieger30 »</TD></TR><TR><TD CLASS="quote">Yes, I did search and did not come up with an answer. I have a d16z6 engine and need it to run off of a obd2b engine harness with the p2p ecu. Is this possible? If not what codes will i throw. Can i just get a coversion harness and run a p28? I need to know what all is involved.
Thanks</TD></TR></TABLE>
will need to get the following
obd2b dizzy( all 96-98 d serie ,96-01 bserie dizzy plugs are the same . 99-00 d serie plugs are different )
obd2 alternator
obd2 injectors
obd2b to obd1 jumper harness wich they are 75$ shipped anywhere
thats if u dont want to hardwire all ur stuff
if u use ur p2p u will trow soo many codes that ur cluster will light up like a christmas tree but if u go obd1 u will not have any code
obd2 alternator
obd2 injectors
daredeezy619
11-21-2008 04:38 PM
