D16Z6 dyno numbers
Subscribe
Feb 9, 2003 | 08:20 PM
Well i finally dyno'ed my d16z6 powered dx hatch. Did 13 runs and the best tune we came up with is 165 whp and 142 wtq at 5 psi.
My mods are:
Greddy kit
Greddy fmic
Hks SSBOV
Sard adj fuel regulator
aem fuel rail w/gauge
aem cam gear
underdrive pulleys
msd 6al w/ blaster coil
Skunk2 exhaust
I think thats all.
Soon to come is arp headstuds, cometic gasket, 450's and hondata.
[Modified by norcalcrx, 5:37 AM 2/10/2003]
[Modified by norcalcrx, 1:35 AM 2/11/2003]
[Modified by norcalcrx, 1:36 AM 2/11/2003]
[Modified by norcalcrx, 4:19 AM 2/11/2003]
Reply 0
Feb 9, 2003 | 08:35 PM
Re: D16Z6 dyno numbers (norcalcrx)
165 whp on a Z6 at 5 psi?
Reply 0
Feb 9, 2003 | 08:38 PM
Re: D16Z6 dyno numbers (Daniel)
yes thanks for the correction, we had 176 whp at 7psi but it was leaning out bad so we went back to 5 psi and tuned it safe.
[Modified by norcalcrx, 5:40 AM 2/10/2003]
Reply 0
Feb 9, 2003 | 08:39 PM
no, i mean, that's pretty impressive for a Z6 to make 165 whp at 5 psi. i didn't know 5 psi could make so much hp on a SOHC.
Reply 0
Feb 9, 2003 | 08:40 PM
Yea...that seems a little high there..but if you say so..but anyways nice #'s..post the graph!
Reply 0
Feb 9, 2003 | 08:41 PM
We were very happy with this considering im using the blue box right now.
Reply 0
Feb 9, 2003 | 09:28 PM
Re: D16Z6 dyno numbers (x lP lL i c i t)
Quote:
post the graph!
Reply 0
Feb 9, 2003 | 09:38 PM
No digi cam or scanner so i will try to get it done tomorrow and post it up after work.
Reply 0
Feb 10, 2003 | 06:45 AM
Good numbers, get some injectors or at least an inline and crank up the boost. I ran 10lbs on my z6 back in the day for ever withno fuel upgrades. besides those motors are cheap I have a couple laying around if anyone needs one.
Reply 0
Feb 10, 2003 | 06:48 AM
Re: D16Z6 dyno numbers (JdmRiceMonster)
any of those with trannys? and how much do they usually run. my motor isn't blowing anytime soon i think. but i'd like to have a contact just in case.
Reply 0
Feb 10, 2003 | 06:55 AM
Re: D16Z6 dyno numbers (leadtrum)
i made 216hp and 190lb on a d16y8 with hondata 2b at 13psi
Reply 0
Feb 10, 2003 | 07:33 AM
Re: D16Z6 dyno numbers (VSM EXtasy)
Is the engine stock? Any problems at 13psi?
Reply 0
Feb 10, 2003 | 07:41 AM
Re: D16Z6 dyno numbers (JT)
engine is stock but recently my car started misfiring, no CE lights. I'm sure the engine is good, something is wrong with the ignition i'm guessiing.
the engine ran great, i took it up to 8000rpm all the time. No valve tapping and good compression.
[Modified by VSM EXtasy, 4:42 PM 2/10/2003]
Reply 0
Feb 10, 2003 | 02:42 PM
i made 274hp 226tq wiht my z6, all stock internals just a head gasket and studs.. 440cc's for fuel with vafc hack approx 13-14psi on that run (had a boost leak).. doin pretty well for a greddy kit at low low boost.. good luck with it
Reply 0
Feb 10, 2003 | 02:55 PM
Re: D16Z6 dyno numbers (BoostedED9)
nice *** numbers...givin us soch turbo some hope
Reply 0
Feb 10, 2003 | 03:56 PM
Nice numbers...espically on the Greddy Kit...what boost controller are you using and is it holding it without any spikes or boost creep??
Reply 0
Feb 10, 2003 | 04:04 PM
we had a dyno day here and a d16z6 put 175whp on 5psi also. want some 450's? check my sig
Reply 0
Feb 10, 2003 | 04:15 PM
definately not a greddy kit... i run a t3t4, it held the boost the whole way, no stpikes or creep
Reply 0
Feb 10, 2003 | 04:21 PM
Are you running stock exhaust norcalcrx? Maybe i missed it?
Nice numbers!
Reply 0
Feb 10, 2003 | 04:38 PM
Re: D16Z6 dyno numbers (ill_take_one)
Im running a skunk2 cat back.
Reply 0
Feb 10, 2003 | 04:50 PM
Ohh...mybad ...anyways thats still impressive with stock internals
Reply 0
Feb 10, 2003 | 04:54 PM
Quote:
Well i finally dyno'ed my d16z6 powered dx hatch. Did 13 runs and the best tunewe came up with is 165 whp and 142 wtq at 5 psi.
What did you actually do...tuning wise since you dont have a adj A/F...did you just mess around with the Cam Gear or Fuel Regulator? Also whats the size of your piping on the Skunk2 Cat-Back?
Reply 0
Feb 10, 2003 | 07:27 PM
We tuned the timing and cam timing. We raised the fuel pressure to 52 psi. I believe the exhaust pipe size is 2.5 I was able to do 13 runs and these are the nicest. I had one run at 175 whp and 155 wtq but i was detonating pretty bad.
Reply 0
Feb 10, 2003 | 07:37 PM
damn, that's impressive. 165 whp, 5 psi, GReddy kit. Gives me some hope.
Reply 0
May 27, 2005 | 10:20 AM
Nice numbers for a Z6. Makes me want to put a Z6 back in my 5th gen Si and turbo it.
Reply 0
Subscribe
