D16z6 custom turbo help!
Old Apr 26, 2004 | 11:58 AM
siksol41's Avatar
Default D16z6 custom turbo help!
I'm planning on building my own turbo kit to run 6-7 psi. I was wondering if anyone has a parts list of the little parts like fittings for oil taps and stuff like that. Also instrustions on the install of running lines and oil. Are the stock injectors and fuel pump sufficient, and I was wondering if there is anyone in the are who can do hondata tunning.
Anyones help is much appreciated, Im in a club thats starting up and if things work out with my car their will be others to follow!
Old Apr 26, 2004 | 12:07 PM
8200RPM's Avatar
local hippie
Default Re: D16z6 custom turbo help! (siksol41)
hers a clip of my list: (to give you an idea)
>Oil Feed Kit:
- Brass 1/8" NPT Tee Fitting
- (2) -3AN straight hose ends
- (4) 1/8" NPT to 3AN aluminum fittings
- 4ft of -3AN hose
- Steel 1/8" NPT to 3AN fitting
>Oil Return Kit:
- 2ft of -10AN hose
- (1) -10AN straight hose end
- (1) -10AN 45 degree hose end
- Earl's 1/2" NPT to -10AN adapter
>1/2" NPT T3 Oil Drain Flange
>Garrett T-3 Turbine Housing Inlet Gasket
>Garrett T-3 Turbine Housing Discharge Gasket
>Garrett Oil Drain Gasket
>Earl's -10 AN male, aluminum, natural finish weld fitting
that was a straight copy & paste
find some dsm injectors- those are sufficient
Old Apr 26, 2004 | 07:22 PM
siksol41's Avatar
Thanks man that helps alot
Old Apr 27, 2004 | 09:38 AM
siksol41's Avatar
Does anyone who has a d16 have 1/4 mile times they're running on 6-7 psi?
Old Apr 27, 2004 | 07:15 PM
8200RPM's Avatar
local hippie
Anytime Im a girl... not a "man" lol but thats ok!
Try IMing D1se7enTurbo... he will be able to help you out ALOT.
He is CivicRyda2k on here.
Old Apr 28, 2004 | 04:29 AM
M.A.R.C.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siksol41 &raquo;</TD></TR><TR><TD CLASS="quote">Does anyone who has a d16 have 1/4 mile times they're running on 6-7 psi?</TD></TR></TABLE>
I ran 14.8 @ 6psi on a T3 60 trim. My clutch started to slip on that run and my next runs weren't clean at all. I guess I coulda done a 14.6 @ 6psi
Old Apr 28, 2004 | 01:48 PM
tgreaves's Avatar
I ran a 14.76 on 3 psi non-intercooled with a Airesearch T3 .48/.42
levee000
Jul 11, 2008 10:27 AM
harryg
Dec 2, 2003 12:02 PM
Poop111444
Jul 8, 2003 06:08 AM
gsrcivict
May 29, 2003 09:41 AM
jdmtegxsi
Jan 20, 2003 03:36 PM
