D16z6 catch can question.......
Old Nov 15, 2006 | 11:51 AM
photec2's Avatar
Default D16z6 catch can question.......
do i take my PVC valve out and have a line going directly to the black box on the back of the block that it is connected to? or take the vaccum line off and go from PVC valve to catchcan then to intake before turbo???
Old Nov 15, 2006 | 01:12 PM
RyanEJ8's Avatar
Default Re: D16z6 catch can question....... (photec2)
Do you want an open or closed loop setup?
If I were you I'd rather have the setup open then route that crap into my turbo.
Old Nov 15, 2006 | 01:32 PM
photec2's Avatar
Default Re: D16z6 catch can question....... (RyanEJ8)
in assuming mine is closed, i do not have a breather on the can ... where do the lines go? i think the way i have it is wrong
Old Nov 16, 2006 | 09:07 AM
photec2's Avatar
anyone....?
Old Nov 16, 2006 | 11:51 AM
sh!tsWEAK!'s Avatar
bump, I'm interested as well.
Old Nov 16, 2006 | 04:39 PM
platinum00's Avatar
search guys.. there are 1000 threads on this.
you can set it up anyway you like... this is how i set it up, but by no means am i saying its the correct way
2 catch cans - 1 small, 1 larger, both have 2 fittings and breathers on top.
the smaller one is connected to the head via 2 fittings i welded to the valve cover. the stock location on the back of the valve cover just has a little breather filter on it now.
the larger one is connected to the black box on the back of the block. the second fitting was closed off.
All unused vac port on the intake manifold were blocked off
platinum.
crazyhouse2011
25
Mar 15, 2013 02:52 AM
Blue94Accord
Apr 19, 2012 08:01 PM
BDaTurboTeg
May 21, 2007 06:21 PM
93egallmotor
Apr 21, 2007 01:45 PM
mike93boost
Jan 31, 2006 07:28 PM
