D16y8 turbo questions...
Old Aug 3, 2004 | 06:20 PM
DruWO's Avatar
Default D16y8 turbo questions...
What did you do with that air sensor that plugs into the intake pipe? Will i throw a CEL if that sensor reads boost? And does anyone know if its possible to lower boost levels on an internally wastegated turbo (maybe with a MBC??? ), cause i've heard that you can only raise boost levels and not go any lower than what its set at...
thanks a lot!
Old Aug 3, 2004 | 08:41 PM
DruWO's Avatar
help..
Old Aug 3, 2004 | 09:21 PM
honda9369's Avatar
Default Re: D16y8 turbo questions... (DruWO)
i believe your talkin about the iat sensor. place that on your charge pipe(b4 the turbo)
Old Aug 3, 2004 | 10:02 PM
DruWO's Avatar
oh yeah...makes sense..haha
thanks a lot!
Old Aug 4, 2004 | 10:13 AM
tgreaves's Avatar
Default Re: D16y8 turbo questions... (honda9369)
You dont place the iat before the turbo.. If you do that the ecu isnt getting accurate reading for the intake temps since the intercooler is going to change them.. I would put the iat in the charge pipe about 6" from the throttlebody..
Old Aug 4, 2004 | 01:55 PM
RyanEJ8's Avatar
Default Re: D16y8 turbo questions... (tgreaves)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">You dont place the iat before the turbo.. If you do that the ecu isnt getting accurate reading for the intake temps since the intercooler is going to change them.. I would put the iat in the charge pipe about 6" from the throttlebody..</TD></TR></TABLE>
That's what I'm going to do.
Ross 2.0
Sep 26, 2007 12:38 PM
spotscivic
Aug 7, 2007 10:53 PM
Honda_Driver
Nov 13, 2005 10:37 AM
IDriveHonda
May 19, 2005 06:50 AM
00BoostedD16
Nov 9, 2004 09:39 AM
