D16y7 + p28 + Hondata s200 = any problems?
I am about to finish up my Hondata setup and I am wondering if I will run in to any issues with running a p28 w/ my D16y7. The only thing that comes to mind to me is the IACV is located on the TB and not the IM..like the z6, y8 etc...
Anyone care to share?
Re: D16y7 + p28 + Hondata s200 = any problems? (Tinker219)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tinker219 »</TD></TR><TR><TD CLASS="quote">start her up!</TD></TR></TABLE> edit: i don't think there will be any problem, it will run fine.
haha....
Modified by @irborne at 3:16 PM 5/6/2003
haha....
Re: D16y7 + p28 + Hondata s200 = any problems? (CzanSOHC)
For whatever it's worth, I run a Hondata with a P06 ECU running a P28 program on a D16A6...never had any problems, I just had to disable the VTEC sensors.
-Seth
-Seth
Well, I was right. I just got everything hooked up and now I'm throwing a code 14 and my idle is jumps from 1500 to 1600 RPM rapidly. ANything I can do. Hondata lists the p28 as an ecu that supports the y7. Somebody help me.
Re: D16y7 + p28 + Hondata s200 = any problems? (Spunkster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spunkster »</TD></TR><TR><TD CLASS="quote">What error code are you getting? Please give more details so that we can attempt to help you.</TD></TR></TABLE>
He stated Code 14 in his post above..
Yes, code 14, IAC. Idle jumps from 1500-1600 rpm and the fast idle valve is sucking in air all the time...like on a cold start but the car never gets up to temp and the idle never drops. Can this be fixed with Hondata's rom editor?
Sorry, I didn't see the error code earlier. Not sure about the code, but you can adjust the idle settings in romeditor. It will allow you to adjust the IAC duty cycle either up or down. This alone may solve the code 14 error.
thirsk66
02-02-2015 10:41 AM
