d16a6 build wtf?
Old Jan 17, 2006 | 01:35 PM
bennyhonda7's Avatar
Default d16a6 build wtf?
have topline bearings, vitara pistons,eagle rods, in ad16a6 in my 95 coupe, with z6 tranny wtf it gets an oil psi light, the compression on all 4 is around 120-125 ignition breaking up under boost not even 20 miles on motor...what could be going on?
Old Jan 17, 2006 | 01:56 PM
splitime's Avatar
Default Re: d16a6 build wtf? (bennyhonda7)
Built wrong... very low compression motor with those pistons in an a6 (7.5:1)... or a combo of both.
Old Jan 17, 2006 | 02:52 PM
Default Re: d16a6 build wtf? (splitime)
wouldnt i still be able to feel boost etc...go decently fast...i thought that with lower compression i could run more timing, and more boost...what the expletive even if there was 7.5.1 wouldnt it still be a decent motor with more boost...or should I mill or head swap...z6 maybe...
Old Jan 17, 2006 | 03:52 PM
splitime's Avatar
Its just low, ie: crappy when out of boost. It shouldn't cause motor to fail or anything though.
If you are getting an oil light, I'd check oil levels, check that wiring to oil (dummy) light is connected firmly,
Beyond that, the breaking up could be timing, plugs, tune etc.....
Old Jan 17, 2006 | 04:04 PM
platinum00's Avatar
what management are you running
why are you boosting the motor with a oil light on
fix the oil light and get the car tuned and i bet most of your problems go away
platinum.
Old Jan 17, 2006 | 04:41 PM
so the motor should run pretty decent in boost then correct? i can boost more and run more timing with the lower comp ie have more torque in boost...? and i stopped driving when the light flashed and have yet to drive it im a pulling the pan and checking the pump
Old Jan 17, 2006 | 05:02 PM
platinum00's Avatar
good idea.
are you running the car un-tuned? it kinda sounds like it
platinum.
Old Jan 17, 2006 | 05:04 PM
Default Re: d16a6 build wtf? (platinum00)
actually im running uber i have a wideband, and am using my d16a6 map from before the build 6psi,dsm450s 14b turbo, stock motor...now with different comp i need more timing the fuel is still fine actually a little rich...
Old Jan 17, 2006 | 08:20 PM
platinum00's Avatar
does the car run fine out of boost.
platinum.
Old Jan 17, 2006 | 10:36 PM
sohc_turd's Avatar
wouldn't low oil pressure possibly point to poor main bearing clearances and other things??
How where the clearances when you put the motor together? plus, whats your total timming @ the boost levels your running?
i'm no pro builder but thats what i would have checked.
Old Jan 18, 2006 | 01:06 PM
Default Re: d16a6 build wtf? (sohc_turd)
runs fine out of boost...and below 60%throttle...
Old Jan 18, 2006 | 01:43 PM
redzcstandardhatch's Avatar
something different
i HATE topline bearings... i've seen them fail a couple times, quickly. you might want to think about making sure they arent falling apart and causing low oil pressure. did you check the clearances on the bearings?
Old Jan 18, 2006 | 01:49 PM
HiProfile's Avatar
Well what ignition timing maps did you use? I'm going to guess your timing is messed up due to the obd0 head/motor converted to obd1. Check your base timing, it should be 16*. Also check to see that the ign map is the correct one you'd be using for the a6, and that it does have a bit more timing added due to the veeery low compression.
My suggestion would be just to get a z6 head, since you're 2/3 of the way there. That way you can start with a real stock ign map and still have a rough base fuel map to tune from, as well as have around 8.5:1 compression. BTW, z6 heads are about 34.6cc, a6 is 38cc.
Old Jan 18, 2006 | 02:58 PM
Default Re: d16a6 build wtf? (HiProfile)
i just really want to get the car running and then possibly head swap etc....yeah possibly ignition adjustment...
rak511
Jul 4, 2013 11:17 AM
kid_honda
Aug 26, 2008 05:29 PM
MUGEN_EG95
10
Oct 25, 2007 07:24 AM
BoostR41
Apr 7, 2005 08:44 PM
1 Cam Wonder
44
Nov 23, 2004 08:18 AM
