d16 vitara trouble
Old Apr 6, 2009 | 09:51 AM
Nichelson_Performance's Avatar
Default d16 vitara trouble
does anyone know what the maximum piston to wall clearance is for stock bore vitara's? and what the lowest cranking pressure (compression) can be?
this build is about to hit one year sometime this month, but i've noticed the pistons have gradually getting louder which is probably due to the fact the pistons are beating up my cylinders.
heres the thing though, the car still starts fine if not better than it did before and it still hits and carries boost fine, but on the downside it is smoking some more than usual, but it always has because i never changed valve seals yet. the other thing is that it rarely uses oil even with the blowby, so could the blowby be causing the excessive smoke or maybe the turbo seals.
i'm going to do a compression test to see how much it lost from last year. it checked out last year making around 138 psi with only 1-2 psi variation between the cylinders.
DulinDragons
Dec 3, 2009 09:05 PM
GSR_hatch936
48
Dec 28, 2007 11:12 AM
SOHC_MShue
Jan 16, 2007 04:21 AM
bdpetska
Jul 18, 2006 04:12 PM
junkyard racer
Oct 31, 2004 05:32 PM
