D16 turbo question.
Old Sep 30, 2013 | 06:18 PM
Jorgeb94's Avatar
Icon2 D16 turbo question.
So I finished installing my turbo kit. It's a Godspeed .57ar eBay brand. Now I put it backwards so it would fit Ac. Now my boost gauge is reading -5psi. Why is that? There's no leaks within the ic piping. Could it be the position of it? Or how about the waste gate. I put a 5psi spring in it and still nothing. Even hooked up a aem boost controller/ gauge and again nothing it's just reading negative. Also when I went to dyno also negative boost the car was doing 120whp. Help please. If you need more info let me know please.
Old Oct 1, 2013 | 03:13 AM
SlowSOHC-T's Avatar
Default Re: D16 turbo question.
So its pulling 5in of vacuum? that would "negative boost".... If thats the case then you have a major vacuum leak, you should be seeing around 25in of vac. at idle. Unless you're running the AEM true boost gauge then you're seeing 5lbs of positive pressure.
Do you have a wideband?
Any CEL's?
Setup info...
Old Oct 1, 2013 | 06:10 AM
serg86's Avatar
so does your car at iddle is boosting 5psi? or at iddle you have 5psi vacuum?
i would start to intalling the turbo kit for what is designed. meaning install it the way they say its supposed to be installed.
second check the vacuum lines from your compressor housing, west gate, gauge etc.
Old Oct 1, 2013 | 08:12 AM
SlowSOHC-T's Avatar
What do you mean? Regardless if the turbo is mounted with the compressor facing driver or passenger side it wouldn't be an issue.
Old Oct 1, 2013 | 01:43 PM
Dark_Teg's Avatar
Can you post some pics of your set-up?
Old Oct 1, 2013 | 04:10 PM
motoxxxman's Avatar
Originally Posted by SlowSOHC-T
So its pulling 5lbs of vacuum? that would "negative boost".... If thats the case then you have a major vacuum leak, you should be seeing around 25lbs of vac. at idle. Unless you're running the AEM true boost gauge then you're seeing 5lbs.
Any CEL's?
Setup info...
you mean 25 inches of vacuum at idle? lol.
OP, take a vid of your boost guage while idling, and blip the throttle a few times.
also take a pic of where the boost guage is connected to the engine.
Old Oct 2, 2013 | 06:18 AM
SlowSOHC-T's Avatar
Yeah you know what I mean. lol
Old Oct 2, 2013 | 07:10 AM
Dark_Teg's Avatar
Im sure you both meant HG's of Vacuum.
Old Oct 2, 2013 | 03:48 PM
Jorgeb94's Avatar
Alright guys sorry I've been gone for a bit. Busy w/ school. But here's the thing. When at idle it's at -5 sometimes -6. When I drive and and I push on it meaning flooring it it goes up to -1 or 0 but won't go past 0. I'll post pics as soon as I get the car back hooked up right now I have everything off to replace the a clones to an ek. I'll post pics soon. Any other ideas as far as what it could be?
Old Oct 2, 2013 | 04:44 PM
motoxxxman's Avatar
well yeah, technically it's inches of mercury, aka in/Hg or "/hg
Old Oct 2, 2013 | 04:45 PM
motoxxxman's Avatar
post pics and vids and we'll tell you.
Old Oct 2, 2013 | 04:54 PM
Jorgeb94's Avatar
Alright as soon as I get it up and running again ill post them. Thanks a lot.
Yoonit1
Oct 27, 2013 06:59 AM
EG-SIXV-TEC
Sep 16, 2013 03:15 PM
nicktagz
Aug 28, 2006 07:56 PM
navz121
Dec 30, 2003 09:23 PM
lildrgn2.0
Feb 25, 2003 07:30 AM
