d16 turbo. problem knocking head
Old Sep 16, 2007 | 09:52 AM
Sohc Turbo's Avatar
Default d16 turbo. problem knocking head
I;m having a problem with my setup. my valve is knocking. it coming more from the dist.. side. i adjust the valve. check and redo the timing. i have ycp piston. a copy of eagle rod call star.. From tunertoys.com i have to notch the block for the rods. i ope the pan and check it again to see if its hitting. and its not. the knock is coming from the valve.. i changed 3 head that i had too. i try useing thinker oil and its the same. i needed in help .. anything got any idea.
Old Sep 16, 2007 | 11:38 PM
JaredKaragen's Avatar
Default Re: d16 turbo. problem knocking head (AllMotorH0nda)
check the lost motion assembly on that side of the head. maybe it is not working correctly?
Is the valve lash gap still the same as what you set it to?
Did you do the valve adjustment when the motor was ice cold (had not been driven for hours)?
Old Sep 17, 2007 | 05:57 AM
Schister66's Avatar
Man U FTW
i agree...check the LMA's. I had a ticking noise coming from what i thought was the center of the head last fall, but the timing belt had shredded and was clicking inside the cover...make sure to check the obvious stuff first
Old Sep 17, 2007 | 07:35 AM
ryan89crx's Avatar
sure its not piston slap?
hylaxrng
Dec 17, 2013 11:03 PM
dc2typer01
Oct 16, 2006 08:55 PM
Drizzo
10
Dec 19, 2005 07:41 PM
danteisme
Feb 9, 2004 09:22 PM
Yuleluder
Sep 16, 2002 09:43 AM
