D16 Turbo Build up ques???
Old Sep 14, 2007 | 04:00 PM
BalzeOrangeCivic's Avatar
Default D16 Turbo Build up ques???
I have a 1998 civic ex with a D16Y8 V-Tech 125,000. I want to do a small build up. I am either going to rebuild the engine with OEM parts using a rebuild kit or buy a completed rebuilt stock V-Tech. I want to run a T3/T4 frontmount, 38mm waste gate, greddy BOV and boost controler at about 7psi. Im just looking for a little kick but an everyday driver. Im also putting in a 250 pump, 450cc injectors, regulator and rail. Any advice on parts or it will be ok to rebuild the engine to brandne stock and then put a turbo on. what do u think ill be looking at for HP??
Old Sep 14, 2007 | 04:07 PM
quicksilver1689's Avatar
i ♥ snails
v-tech ftw!
Old Sep 14, 2007 | 04:14 PM
Default Re: (quicksilver1689)
wat??
Old Sep 14, 2007 | 04:41 PM
EASY101's Avatar
* B A N N E D *
lol man...i see ftw all the time. wtf does it stand for?
Old Sep 14, 2007 | 05:12 PM
OLD_HATCH's Avatar
ftw=wtf
lol not realy
it stands for:
For The Win
Old Sep 14, 2007 | 05:25 PM
mercutio_07's Avatar
Default Re: D16 Turbo Build up ques??? (BalzeOrangeCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BalzeOrangeCivic &raquo;</TD></TR><TR><TD CLASS="quote">I have a 1998 civic ex with a D16Y8 V-Tech 125,000. I want to do a small build up. I am either going to rebuild the engine with OEM parts using a rebuild kit or buy a completed rebuilt stock V-Tech. I want to run a T3/T4 frontmount, 38mm waste gate, greddy BOV and boost controler at about 7psi. Im just looking for a little kick but an everyday driver. Im also putting in a 250 pump, 450cc injectors, regulator and rail. Any advice on parts or it will be ok to rebuild the engine to brandne stock and then put a turbo on. what do u think ill be looking at for HP??</TD></TR></TABLE>
You have a sohc V-TEC. V-TECH is a company that makes phones, childrens toys, and other electronics...
B4 you apply FI it's definately a good idea to freshen up everything. i.e. new gaskets, check the pistons and rings, etc.
Old Sep 14, 2007 | 05:54 PM
Tippyman's Avatar
Default Re: D16 Turbo Build up ques??? (mercutio_07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mercutio_07 &raquo;</TD></TR><TR><TD CLASS="quote">
B4 you apply FI it's definately a good idea to freshen up everything. i.e. new gaskets, check the pistons and rings, etc. </TD></TR></TABLE>
The blind leading the blind.
He has VTEC.
Old Sep 15, 2007 | 05:55 AM
Default Re: D16 Turbo Build up ques??? (Tippyman)
LOL! you got me, a definate oversight of copy and paste.
Old Sep 15, 2007 | 09:45 AM
ChampWhiteTegra's Avatar
FTW also expletive The World.
Old Sep 15, 2007 | 04:24 PM
CivicVX94's Avatar
Default Re: D16 Turbo Build up ques??? (ChampWhiteTegra)
that tattoo is hideous
to the op:
you need to be ALOT more specific, you haven't even stated turbo you have/plan to have we need a ton more info to even make a good guess.
search and read up and post back up when you have some more knowledge on the subject. you'll learn more if you learn it yourself other than asking on here
Old Sep 15, 2007 | 07:31 PM
ralph11sec's Avatar
Default Re: D16 Turbo Build up ques??? (CivicVX94)
its a miracle this thread is not flamed yet. lol
try to visit turbod16.com. and READ READ READ there are a lot of setups there what would be similar to yours so you can expect some figures.
CleanAFCivic
Aug 4, 2018 02:01 PM
Jocqui6287
Sep 4, 2014 08:16 PM
1991hb
Feb 15, 2010 10:13 PM
StevenGunn
May 6, 2008 07:20 AM
j-rome
10
Jun 11, 2006 08:22 PM
