power loss ?
Old Sep 14, 2007 | 08:53 PM
turbo-crx's Avatar
Default power loss ?
Long Story Short I Was Driving Home Tonight And My Car Just Shut Off.its A Turbo Crx If That Matters. Anybody Have Any Idea What To Look For? A Fuse? Ground Wire? It Did Start Up After Cranking It For A Min. Then It Shut Off Again 2 Min Later After Driving Luckly I Was Pulling Into My Apartment. So Any Suggestions Would Be Great
Old Sep 14, 2007 | 11:15 PM
MADMAX_zero's Avatar
Default Re: power loss ? (turbo-crx)
Check to see if the fuel pump is coming on and/or hearing the main relay click on. If not bad main relay or bad solder connections. Easy fix to open it up and re-solder all of the connections.
Also could be a bad igniter in the dizzy.
Old Sep 15, 2007 | 06:47 PM
turbo-crx's Avatar
I Figured Out I Dont Have Any Power On My Auxillary Switch Which Is Where Your Key Goes After You Start The Car. Any Idea What Todo Or Look For? Fuses And Grounds Are Good. I Barely Got The Car Home, I Had To Hold The Key Perfectly Still Between The On Position And Auxillary Position
Old Sep 15, 2007 | 08:29 PM
Sounds like the key switch is bad.
It's on the left side of the key cylinder. Held on by two screws.
perpetualburn
Oct 3, 2020 06:08 AM
dtwtouch
Mar 28, 2017 10:51 AM
khock3
Mar 16, 2009 09:32 AM
2001B18C1GS-R
Jun 3, 2008 03:39 PM
demon666999
Jan 9, 2005 10:48 AM
