d16 block?
Old Sep 11, 2003 | 07:42 AM
OoHiTzToMMy's Avatar
Default d16 block?
i have a d16z6 and im going to go turbo on it...i plan on buying a spare block later down the line and im wondering is there any combos that would work for the z6 head and is good for turbo
Old Sep 11, 2003 | 07:53 AM
Default Re: d16 block? (OoHiTzToMMy)
OOh and what are some decent sleeve for the D16
Old Sep 11, 2003 | 08:07 AM
STHPERFORMANCE's Avatar
Golden Eagle Sleeves is what i would use.
I am assuming you are using a D16a6 block or some non-vtec d16. Yes you can slap a Z6 vtec head on it and sure it'll be good with a turbo.
Have you tried to do a search? If not try it.
Old Sep 11, 2003 | 08:15 AM
Default Re: d16 block? (Outkast)
no i have a d16z6 motor but i wanna knoe what types of blocks could i use and which one is stronger for the single cam
Old Sep 11, 2003 | 08:17 AM
gitwidit's Avatar
my buddy just got his block back from Benson. https://honda-tech.com/zerothread?id=605027 looks killa
Old Sep 11, 2003 | 08:31 AM
DigitalFusion's Avatar
do a search on sleeves, and I am sure uw ill come to your own concluesion about which sleeves to go with.
Old Sep 11, 2003 | 03:00 PM
Marauder's Avatar
Default Re: (CustomCockpits)
Send it to RS Machine! The type of sleeves depend on the power level you want. Stand steel sleeves are good for about 350 whp with a turbo....above that, or to hit some nitrous on top of that, use a T-sleeve. A standard sleeve will run about $900, and a T-Sleeve job about $1200.
whypree
Oct 28, 2012 12:30 AM
driftam1
May 9, 2008 08:25 AM
b17 turbo
Nov 23, 2007 01:30 AM
.::Lee::.
Apr 5, 2005 07:15 PM
eg4matze
Oct 12, 2004 02:20 PM
