D16 ARP headstud/head lift question
Old Jun 4, 2006 | 07:32 PM
DelSolMike's Avatar
Default D16 ARP headstud/head lift question
Alright so I finally got my block assembled and in the car with the turbo kit on (not seeing any boost due to removed wastegate spring)and its running great. Once I put the wastegate spring back in once I get it tuned Im worried the head will start to lift. I dont want to drive it around untuned and boosting to put that stress on the bolts and blow a head gasket just to re-torque them. Should I see any problem with the head lifting once I get it tuned? The studs are torque'd at 65lbs. Im thinking get it tuned on the dyno (only to 12lbs of boost) and drive it home, staying out of boost, and re-torque the head studs. Once again this is a d16y8. What do you guys think.
-Mike
Old Jun 4, 2006 | 08:00 PM
CoreyR's Avatar
Default Re: D16 ARP headstud/head lift question (DelSolMike)
you shouldnt have to retorque them.
Old Jun 5, 2006 | 10:19 AM
oscarmayer's Avatar
re-torqueing was back in the old days mostly V-8 stuff. the gaskets were paper and you needed to toqque them 3-5 times in order to get them mashed enough to stay sealed all the time no mater what.
You should be perfectly fine with the head not lifting.
you need to make sure you get the car tuned before you melt the motor down. you should NOT be driving an untuned car around as it's just asking for a ruined motor.
Old Jun 5, 2006 | 11:46 AM
coneheadsracing's Avatar
Default Re: (oscarmayer)
course he said his wastegate is unhooked and not making any boost, be pretty hard to mess up your motor that way.
Old Jun 5, 2006 | 11:56 AM
igo4bmx's Avatar
you can always check before the dyno that the arp's are still torqued properlly.
In my case, i didn't have the headlift until a year later after my dyno session... so I'm assuming my sleeves walked too much and caused my hg to go
Old Jun 5, 2006 | 03:30 PM
DelSolMike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oscarmayer &raquo;</TD></TR><TR><TD CLASS="quote">
Reading pwns j00. Just driving it to my tuner with out the wastegate spring in so the car won't see boost. I'll be putting the spring in right before it hits the dyno.
Thanks for the inpuy about the h/g everyone.
Old Jun 5, 2006 | 06:47 PM
nerdsports's Avatar
ive read that you should retorque them after a heat cycle. so let the car run until normal operating temp, then retorque the head. you should be fine.
btw, why do you have to take out the wastegate spring?? no self-control?
Old Jun 5, 2006 | 08:31 PM
platinum00's Avatar
Default Re: (nerdsports)
it wont hurt to check them. but they shouldnt need re-torqued.
i would not drive your car hard without a wastegate spring. overspoolin the turbo is not a good thing
platinum.
Old Jun 5, 2006 | 08:47 PM
EK k kay's Avatar
Default Re: (platinum00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinum00 &raquo;</TD></TR><TR><TD CLASS="quote">it wont hurt to check them. but they shouldnt need re-torqued.
platinum.</TD></TR></TABLE>
Isn't that the point of removing the spring? To keep the wastegate port open and let the exhaust gas go out freely so that you don't overspool the turbo?
Old Jun 6, 2006 | 03:51 AM
CoreyR's Avatar
Default Re: (EK k kay)
yep, its when you have the WG hooked up but removed a charge pipe from the loop that it overspins the turbo.
Old Jun 6, 2006 | 03:57 AM
platinum00's Avatar
Default Re: (CoreyR)
if that's the case i stand corrected.
platinum.
85mmek9
Apr 19, 2010 08:25 AM
hangac1093
Dec 12, 2006 02:38 PM
VTgringo
Dec 20, 2003 01:11 PM
Ri5e
Sep 9, 2002 01:13 PM
