D15 Oilpan on a D16?
Hey everyone,
I am currently deep in my Single Cam Vitara build, and i have been using a D15 block to mock up my turbo setup. This is so i can build my downpipe and oil dump placement, wastegate dump etc etc....
Anyways, i am wondering if anyone knows if the oilpan off a stock D15 will work on my D16 built motor?? I figure i might as well just use the D15 oilpan since i am using the block to mock it up anyways.
So any one know if it will work?
a jdm d15b is the same, but i'm not 100% sure about a usdm d15.They should be the same. As long as you use the oil pickup from the d15 it will be fine even if it is diff.
