D-Series ARP Head studs question
Old Dec 16, 2004 | 12:20 PM
  #26
Boltz's Avatar
Default Re: D-Series ARP Head studs question (dornon13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dornon13 &raquo;</TD></TR><TR><TD CLASS="quote">aight here is my dillema...i have read the many discerning threads on heads lifting so i thought i would go ahead and get some arp headstuds to hopefully free me from the worries of all that...but i am wondering if i can install these without changing the headgasket </TD></TR></TABLE>
Thats pretty funny.
You want to get some arp's to avoid head lifting but dont want to change the headgasket when you do. Think of it as re-using a condom, just dont do it.
With the SOHC especially prone to head lifting, you want to take all the precautions so you dont have to take it all apart again
Old Dec 16, 2004 | 01:27 PM
  #27
dornon13's Avatar
Default Re: D-Series ARP Head studs question (Boltz)
it was just a thought
Old Dec 16, 2004 | 02:35 PM
  #28
pip9's Avatar
my head lifted and i had arp headstuds. one of the threads in the block for the studs stripped though, thats why it was leaking. ...still just b/c u get the studs doesnt mean that it wont lift up on u. Lots of other things come into play ie.. straightness of the block and heading mating surfaces...torque specs...new headgasket...
Old Dec 16, 2004 | 04:35 PM
  #29
Street Ghost's Avatar
Default Re: D-Series ARP Head studs question (pip9)
So my head lifts only under boost and I'm only pushing 6.5psi, making 195whp. But I have no overheating/coolant issues whatsoever.. is it still completely neccessary to get the block decked? My coolant overflow only fills up when I boost (I know because I saw it happen on the dyno), but under normal driving it stays between MIN/MAX... no overheating or anything.
I was thinking about just getting ARP headstuds and a new headgasket.. but now, I dunno...
Old Dec 17, 2004 | 12:56 AM
  #30
greyzone's Avatar
I used GReddy 2 ml (thicker) headgasket (to lower compression) with ARP studs and blockguard. Boosted 10 psi for 80,000 miles with 200whp with zero problems.
If it works don fix it.
Old Dec 17, 2004 | 01:11 AM
  #31
liam821's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dornon13 &raquo;</TD></TR><TR><TD CLASS="quote">aight here is my dillema...i have read the many discerning threads on heads lifting so i thought i would go ahead and get some arp headstuds to hopefully free me from the worries of all that...but i am wondering if i can install these without changing the headgasket i mean what if i take one stock one out and replace it with an arp one at a time(torqued to spec of course) but would that mess up the way you torque them from what i understand you have to torque them in order..so i just wonder if it would be stupid to do it that way? i just dont want to have to take the head off basically but i really dont want to have head gasket/head lifting issues thanks ..oh yeah its a d16y8 if it makes a difference
Modified by dornon13 at 8:06 AM 12/16/2004</TD></TR></TABLE>
I have DSM friends that do this same thing. Undo each bolt one at a time and then retorque. Its pretty ghetto but it works and they havent had any problems.
I mean the worst thing thats gonna happened is it wont work right and you blow a headgasket. No big deal you didnt really waste alot of time and no money.
liam
lsvtec_cp
Jul 1, 2009 06:22 AM
b17 rolla
Jan 12, 2009 09:01 PM
memorybox
Oct 21, 2006 09:02 PM
1.8T_EG
Jan 9, 2003 08:24 PM
infamousALLMTR
Sep 24, 2002 11:01 AM
