cyp (cylinder postion code)?
Old Apr 26, 2003 | 11:31 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default cyp (cylinder postion code)?
i have this code and also one for fuel injectors. what should i be checking? isn't that sensor in the distributor? also for these two codes the car won't rev past 3200. this is all happening on a b16 with maxrev turbo kit...put in 450cc injectors and the hondata base map chip. i even tried to run a stock ls ecu and stock injectors and it still hits the 3200 rev limit so i am thinking it has to do with the cyp sensor and not the injectors besides they are brand new. thanks
-kevin.
Old Apr 26, 2003 | 11:35 AM
DaveF's Avatar
Default Re: cyp (cylinder postion code)? (not so civic)
id say if its a cyl pos code than pull off the distributer cap and check all of the sensors inside of it, sometimes they get "torn up"
did the car run fine before all of these "mods"???? what hae you changed on it recently that could be the culprit of your problems?
Old Apr 26, 2003 | 11:46 AM
Default Re: cyp (2.2Lcivic)
yeah the car ran perfectly fine before. all i did was install the new 450's, didn't mess with any ecu harness wires (just the chip in the ecu) and install the gauges and turbo timer which i doubt has any thing to do with it. i did pull the head and put new head gasket and head studs so i don't know...something may just not be plugged up or plugged up wrong which i doubt. i'm about to go and check everything over very close...any more ideas are welcome. thank you.
Old Apr 26, 2003 | 01:28 PM
DaveF's Avatar
Default Re: cyp (not so civic)
could the timing belt be off by a tooth??
Old Apr 26, 2003 | 02:37 PM
i found it...the timing was 180 off . oh well, it's fine now. you were on the right track. thanks.
-kevin.
dre33333
Nov 22, 2012 05:17 AM
turbohb91
Mar 30, 2005 07:53 AM
crxforum
Jun 12, 2004 06:07 PM
n*hance*ek
Dec 9, 2002 06:09 PM
