cut-out
Old Oct 16, 2008 | 01:26 PM
avotegra's Avatar
Default cut-out
has anyone try hooking up there exhaust cutout to there second butterfly... use as a open switch......
Old Oct 16, 2008 | 03:25 PM
boosted k20's Avatar
Default Re: cut-out (avotegra)
u mean hook it up to the secondary's from the IM? why would u wanna do that. it will be pointless. just run it like how its meant to be run via a switch.
Old Oct 16, 2008 | 10:54 PM
avotegra's Avatar
Default Re: cut-out (boosted k20)
if you have a 3inc..already..but want that extra boost at 5200rpm.......kinda like a loud vtec....would't that be great........
Old Oct 17, 2008 | 03:49 AM
u do realize that it takes a couple of seconds for the valve to open right? so once u the IAB sends its signal, ur gonna be boosting the car while the plate is trying to open. imo its pointless. plus once the valve opens, how r u going to close it? the polarity on the voltage needs to be switched in order to close the plate. just use the switch method that came with the cutout
Old Oct 17, 2008 | 12:38 PM
avotegra's Avatar
but a switch is open by hand right..................but if you use this iab....kinda like a vrommmmperaaaaakinda like a loud *** vtec............iam pretty sure it'll be bad ***.......if you can get it to work.........once you go pass 5200 it'll always be open...right........
smokinloc
Sep 10, 2010 11:26 AM
bsmith100
Audio / Security / Video
Jul 23, 2010 09:30 AM
B18EG6
Jul 23, 2008 01:03 PM
2ltrsnailpwr
Nov 27, 2003 05:57 AM
davew
Aug 28, 2001 05:57 AM
