Custom wastegate dump
Old Apr 22, 2003 | 07:16 PM
  #26
95integrags-r's Avatar
Default Re: Custom wastegate dump (Boosted97Lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted97Lude &raquo;</TD></TR><TR><TD CLASS="quote">why does everyone always dump it out the drivers side?? if the wastegate is located on the tranny side of the engine, than couldn't you dump it out the passenger side?</TD></TR></TABLE>
cause you get to watch the flames shoot out when your driving
Old Apr 22, 2003 | 07:17 PM
  #27
nerdsports's Avatar
maybe charge pipes get in the way. ????? im internal wastegate....
Old Apr 22, 2003 | 07:18 PM
  #28
Boostless97Lude
Guest
Posts: n/a
Default Re: Custom wastegate dump (95integrags-r)
shieett..... seein them in my rearview is blinding enough already, i don't need them coming at my face
Old Apr 22, 2003 | 08:12 PM
  #29
tony1's Avatar
Default Re: Custom wastegate dump (EFrollingout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFrollingout &raquo;</TD></TR><TR><TD CLASS="quote">How is the pipe run is there a flex section on the dump tube. Is it connected to the bumper or is it just floating in the cutout of the bumper. How is it done I wont to see under the hood. </TD></TR></TABLE>
That's the hard part, the stuff you don't see. The pipe is two pieces with a deltagate flange on each side to connect the two. There is a 1.5" flexpipe on the second section and the pipe after the flexpipe is secured directly to the chassis. If you don't do it this way then you'll have to have a pretty big hole to clear the pipe when the engine torques. It looks simple from the outside, but it actually takes a lot of time to do it right. I spent a full day making that one. It's all worth it in the end though...
Old Apr 22, 2003 | 09:43 PM
  #30
boostaholic's Avatar
Default Re: Custom wastegate dump (tony1)
That's the same way i made mine. Two peices, one welded to a flange to the wastegate and a short section of pipe welded to a backplate on the bumper. Then i used a thermo wrapped flexpipe in between. If you just had the pipe free floating in the hole, it would hit all over the place when the motor torques.
Old Apr 23, 2003 | 03:58 AM
  #31
slowsi00's Avatar
i want one
so pimp....so pimp
shooting flames out of your car just sounds cool...
what about the carbon and dirty stuff that comes out of there does it spary all over your car or what???
but for the work
i wish i had the mad skillz so i could do it my self.
anyone get a groupbuy going??
Old Apr 23, 2003 | 10:51 AM
  #32
15psi of fun's Avatar
so i don't get a pic of under the hood?
and the plate on the bumper looks cool good job
Old Apr 23, 2003 | 11:33 AM
  #33
Charlie Moua's Avatar
Ok lets clear some things up....
1) it doesn't shoot out flames right.... i mean be seriouse now...
2) are there any hp or performance gains in this mod? beside it makeing more noise and looking cool?
3)what does it sound like?
4)how much exhust fumes are actually realeased?
Old Apr 23, 2003 | 12:00 PM
  #34
EL'ation's Avatar
Default Re: Custom wastegate dump (Charlie Moua)
I liked to know too.
Does it bother you when you have your window rolled down in traffic?
Old Apr 23, 2003 | 12:15 PM
  #35
Boostless97Lude
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua &raquo;</TD></TR><TR><TD CLASS="quote">Ok lets clear some things up....
1) it doesn't shoot out flames right.... i mean be seriouse now...</TD></TR></TABLE>
why wouldn't it?? my exhaust shoots flames, that's all that comes out the the dummtube are hot, gasoline filled exhaust fumes
Old Apr 23, 2003 | 09:39 PM
  #36
tony1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFrollingout &raquo;</TD></TR><TR><TD CLASS="quote">so i don't get a pic of under the hood?
and the plate on the bumper looks cool good job </TD></TR></TABLE>
Old Apr 23, 2003 | 09:41 PM
  #37
tony1's Avatar
Old Apr 23, 2003 | 09:58 PM
  #38
TEAMGENDAI's Avatar
Default Re: Custom wastegate dump (boostaholic)
looks good!!
Old Apr 24, 2003 | 12:40 AM
  #39
mskibbz-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">
Here's one i did recently...</TD></TR></TABLE>
That is sick
Old Apr 24, 2003 | 04:03 AM
  #40
anyone wanna answer my questions?
Old Apr 24, 2003 | 05:29 AM
  #41
silverEH2's Avatar
Default Re: Custom wastegate dump (EL'ation)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL'ation &raquo;</TD></TR><TR><TD CLASS="quote"> I liked to know too.
Does it bother you when you have your window rolled down in traffic?</TD></TR></TABLE>
not unless you are boosting through traffic
Old Apr 24, 2003 | 05:45 AM
  #42
slowsi00's Avatar
4)how much exhust fumes are actually realeased?</TD></TR></TABLE>
1. it will shoot out flames... kinda big ones too depending on boost.
2. it will flow better than routing it threw the exhasut
3. open wastegate but cooler since it will be louder on the out side of your car
4. i dunno
Old Apr 24, 2003 | 06:26 AM
  #43
tony1's Avatar
Default Re: Custom wastegate dump (slowsi00)
1) It shouldn't shoot out flames if you're tuned right. Running too rich can cause flames to shoot out.
2)There is no hp gain compared to dumping striaght down, but it's actually quieter this way. The longer pipe quiets it and the flexpipe acts as somewhat of a resonator.
3)It sounds better than dumping it under the car, more of the jet sound w/o the exhaust sound, if that makes any sense.
4)The only time fumes will come out is when you're at full boost and the wastegate is open, nothing to worry about.
Old Apr 24, 2003 | 06:58 AM
  #44
COLORPROS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">1) It shouldn't shoot out flames if you're tuned right. Running too rich can cause flames to shoot out.
is open, nothing to worry about. </TD></TR></TABLE>
Well put.My thoughts exactly.
Old Apr 24, 2003 | 07:38 AM
  #45
khang77642's Avatar
Default Re: Custom wastegate dump (COLORPROS)
hey tony what size flexpipe is that ?BTW, Excellent job !!!!
Old Apr 24, 2003 | 07:59 AM
  #46
Finest's Avatar
Default Re: Custom wastegate dump (khang77642)
Damn, only Tony could get way with using stainless tubing throughout on EVERYTHING! Is that flexpipe stainless too? LOL! Great job! And pretty welds too!
Old Apr 24, 2003 | 03:25 PM
  #47
Thanks for the under hood shots it gives me a lot of ideas it’s really clean and the craftsmanship looks nice where did you get that small of flex pipe?
Thanks agene for the pic’s Tony
Old Apr 24, 2003 | 06:42 PM
  #48
Boostless97Lude
Guest
Posts: n/a
how did you flare the tip like that Tony?? that's hella tight
Old Apr 24, 2003 | 07:13 PM
  #49
Chrome Pipes's Avatar
Default Re: Custom wastegate dump (mskibbz-T)
WOW! I was thinking about doing this and now after seeing this I am definetly going to make it happen. I can't wait to see what happens when I hit the 2-step!
Tony - Is the wategate pipe mounted to the body with a bracket or is it just bolted to the wastegate?
Old Apr 25, 2003 | 11:15 AM
  #50
TurbodCX's Avatar
Default Re: Custom wastegate dump (Chrome Pipes)
Why the 2 step?? are you going to see full boost on the 2 step?? if so then what are you boosting like 2-3 psi??
Brian
