Custom Turbo or Kit?
Old Nov 24, 2003 | 07:40 PM
The G2 Racer's Avatar
Default Custom Turbo or Kit?
Working on a fully built CRVTEC here.
It's got a 99 Si/SiR B16A head with valve springs, ss valves, crower stage 2 turbo cams, skunk2 cam gears, skunk2 intake mani, arp head bolts, port and polished and a 5 angle valve job.
Block is a B20, sleeved with Golden Eagles Godzilla sleeves, eagle rods with arp rod bolts and JE pistons sporting a 9.5:1 CR. Car will be tuned with AEM EMS.
This thing will take some serious power so I'm wondering what kind turbo, manifold and fuel stuff I should run? Or should I just get a kit?
I want to be able to make some serious power here.
Old Nov 24, 2003 | 07:46 PM
patdemps's Avatar
Default Re: Custom Turbo or Kit? (The G2 Racer)
If you want serious power then your definately going to want to go custom....
Do I hear the echo of sc61???????
sounds like you have a mean setup going
Old Nov 24, 2003 | 08:10 PM
1sicsol's Avatar
Default Re: Custom Turbo or Kit? (patdemps)
I would buy a decent used kit. Less headace and hastle. It all depends on you budjet. If you got the money then do it.
I wouldnt bother with the port polish thing. It doesnt do alot for fi compared to the cost to do it. But if you got the money every pony counts. Im sure it wont matter from the power you can make form this set-up.
Good luck,
Mike.
Old Nov 24, 2003 | 08:22 PM
patdemps's Avatar
Default Re: Custom Turbo or Kit? (1sicsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sicsol &raquo;</TD></TR><TR><TD CLASS="quote">I would buy a decent used kit. Less headace and hastle. It all depends on you budjet. If you got the money then do it.
Good luck,
Mike.
why less headache and hassle? put together kits are the ones you always change eventually down the road. your "better off" piecing a kit together, better products and more power......
Old Nov 24, 2003 | 08:24 PM
I'm going to do a custom set up.
If anyone can give me some help in putting it together, it be great
Old Nov 25, 2003 | 06:08 AM
mike1114's Avatar
stick with a lot of people on here, they sell great parts!!
Flamenco-T with the bad *** stainless steel feed/oil return lines
Tinker219 or FFgeoff for tight manifolds
ebay or johnnyracer or tryus intercooler (I got one 31 X 6 X 2.75 for $300)
Precision or cheapturbo for turbo
JC whitney buy a bunch or u bends to make intercooler piping (i got for $70)
Roadraceengineering.com for silicone couplers/t-bolt clamps
Better injectors (I got DSM 450cc's and resistor box for $20 from Junkyard)
BUY HONDATA OR AEM EMS!!!
Just use the search buttom a lot!! There's other **** but I was just thinking off my head.
I think a custom kit is better cause you get the better parts that you WANT the first time!!
Old Nov 25, 2003 | 10:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patdemps &raquo;</TD></TR><TR><TD CLASS="quote">Do I hear the echo of sc61???????</TD></TR></TABLE>
Yes you do, with a .63 A/R and a Full Race Prostreet Manifold.
516EK9
52
Mar 3, 2010 09:19 AM
jdmb16turbo
Feb 28, 2009 05:03 AM
bradykiller
May 27, 2005 09:48 AM
The G2 Racer
Nov 30, 2003 11:20 PM
