Custom setup is in and feels evil.
Old Apr 20, 2002 | 02:54 PM
lbz34's Avatar
Default Custom setup is in and feels evil.
Heres my list of parts.
Hondata 4b
dsm 450
str fuel rail
turbo xs blow off valve
turbo xs hp mbc
sfp 4-1 manifold
innovative t3/to4e
tial 35 mm gate
clutch masters flywheel
exedy clutch
ssr competition 16x7
nitto drag radials
full autometer gauges (fuel,boost,a/f,oil)
greddy egt
custom downpipe 2.5 in (me)
custom 2.5 in exhaust (me)
3 in magnaflow
greddy type 24 intercoler(bigger one)
well it took 4 nights (8 hrs per night) after work at the shop to get everything made and in.
I have had very llittle sleep since wed. car feels incredibly strong for 5 psi of boost. I did a lot of porting of every weld and flange throughout the system to try to get a decent flow for my less than good welding skills. The parts work great and the fit and finish is actually pretty good. drove a girls 99 gs-r with greddy kit at whatever psi (no gauges) and my car is a LOT stronger (94 gs-r) at 5 psi.
one problem oil leak at the oil return bung (on pan). pulled pan back off and welded inside and still leaking a little. no leak at idle but after i drive it there is a leak????? any not obvious ideas???
Next stop is dyno. wish i had a digi camera to post pics.
[Modified by lbz34, 1:24 AM 4/21/2002]
Old Apr 20, 2002 | 03:13 PM
SlowAutoLS's Avatar
Default Re: Custom setup is in and feels evil. (lbz34)
enjoy!
all my FI plans just went flying out the window when i saw the lay offs schedule in my paycheck...
Old Apr 20, 2002 | 03:21 PM
SiR Kid's Avatar
New User
Default Re: Custom setup is in and feels evil. (SlowAutoLS)
Clean the pan up ALOT, drain the oil, hose it down in brake cleaner from the outside, let it dry.
JB weld the **** out of it, just around the welding to stop the leak. Problem solved.
Old Apr 20, 2002 | 03:53 PM
Ri5e's Avatar
Default Re: Custom setup is in and feels evil. (SiR Kid)
My friend JB welded his and it's still holding strong for 3 months.
Old Apr 20, 2002 | 03:55 PM
TurboSohc's Avatar
Good luck with it man
Old Apr 20, 2002 | 11:22 PM
lbz34's Avatar
Default Re: Custom setup is in and feels evil. (TurboSohc)
I did weld and jb weld the first time. today i took the pan off and welded inside the pan. still leaking as of this morninig but i looked earlier and it seems to have slowed/stopped. i will know for sure on monday when i can get it up on the lift.
Thanks guys
should be in the mid to low 14's at 6000 ft. alt. on 5 psi
per a 15.0 sec vr6 i took 2-3 car lengths through top of second.
civicnar
Apr 16, 2006 11:42 PM
93DituneEX
Feb 6, 2006 05:20 AM
B00ST2nR
Jul 15, 2004 03:32 PM
JDM_EH2
Aug 9, 2003 11:44 PM
falcongsr
Feb 10, 2003 08:30 AM
