Cooling fan...problems
Old Apr 20, 2002 | 05:55 PM
SlowB16's Avatar
Default Cooling fan...problems
Here is the story - I was pulling into my parking spot and I hear a weird whining noise coming from the engine bay. So I turn my car off and pop the hood. I see that my vac line to the bov is disconnected, I figure that is the problem. I reconnect it and turn the car back on...no noise for a few seconds, then it starts again. I then notice that my radiator fan is not running. I am not sure if it is always supposed to run or not, I dont know. It just seems that since the engine was fairly warm it should be spinning..... does anyone have any ideas?
If I need to change the fan switch, or whatever it is that turns it on, how do I do it, and what does it look like??
heeeeeeeelp
Old Apr 20, 2002 | 05:59 PM
Giuseppe's Avatar
Default Re: Cooling fan...problems (SlowB16)
normaly the fans dont run all the time...
the turn on at a specific temperature..
Old Apr 20, 2002 | 06:21 PM
SlowB16's Avatar
Default Re: Cooling fan...problems (Giuseppe)
Ok. Well that is some what of a relief. It just seems like it used to run all the time. Does anyone know what the whining might be?
Old Apr 20, 2002 | 07:46 PM
#417R's Avatar
It could be a couple of things. Where exactly is the whining noise coming from? Which side of the engine? Need more info
Old Apr 20, 2002 | 11:25 PM
SlowB16's Avatar
Default Re: Cooling fan...problems (b20zkid)
I turned the engine back on, but the noise was gone. The engine was warm from just driving around, and the fan was not spinning, so I didnt want it to overheat while I waited for the noise....so I couldnt really tell you.
mfisher1967
Honda Civic (2006 - 2015)
Aug 21, 2007 08:52 PM
Iron_Forrix
Mar 7, 2007 05:41 PM
k_lude
Jan 17, 2007 06:56 PM
Mike1486
Dec 15, 2004 05:49 PM
