Custom kit....Around a T25....need help...
Old May 4, 2004 | 01:07 PM
breakneckvtec's Avatar
Default Custom kit....Around a T25....need help...
I have a 99 civic SI, b16a. I am thinking of building a custom kit. Heres some questions:
1) Is the T25 a good entry level turbo for me? I dont plan to boost high or make any more than 200 or so whp. What kind of performance, in terms of spool, and pull to redline etc will I get at say 8-9 psi.
2) I know I would need the HKS manifold for this turbo. Where can I get it?
3) importparts.com has a convenient custom kit builder. If I was to order some parts from them, say downpipe, ic pipes, nuts/bolts/connectors, would it work with a T25? Basically I need to fill in the rest around the turbo. How would you go about doing it?
4) I plan to run either a hondata on a P28 or uberdata. leaning toward hondata as I DONT even come close to understanding uberdata. Although, my technically inclined/mechanically inclined friend does. However he has no experience tuning it
Old May 4, 2004 | 02:25 PM
Default Re: Custom kit....Around a T25....need help... (breakneckvtec)
Bump please for some info
Old May 4, 2004 | 04:29 PM
2muchPSI's Avatar
I can tell you the T25 is reallly gonna die out high in the revs, I would try something like a T3, or maybe a 14b.
Old May 4, 2004 | 05:56 PM
big_claw's Avatar
What T25 are you planning to use?
Some T25s like off a DSM would not bolt to an HKS manifold.
Old May 4, 2004 | 07:00 PM
traction issuez's Avatar
try a T3 from a volvo or someshort because a T25 is just plain small -- even on sohc 1.6 they run out of air. Or you can get expensive with the HKS manifold if you get a silvia or S13 blah blah (TURBO 240SX) turbos -- their like T28s? and HKS have alot of stock setup for them.
i say T3 -- go big or go home.
Old May 5, 2004 | 11:17 AM
Default Re: Custom kit....Around a T25....need help... (boostedrotary)
I have to look into the specifics on the turbo, however it isnt off of a DSM, its a T25 though so I think it works with the HKS manifold, I will check.
I know this is going to fall off up top, I dont expect it to pull 8psi all the way up. However I will be going with a custom 3" DP to a high flow cat to a 3" exhaust. This should help the turbo up top with breathing no?
kpjo4
Oct 24, 2009 10:39 PM
KStuned
Nov 28, 2005 05:38 PM
Nextelbuddy
Jul 2, 2003 09:09 PM
dc2_and_ef
Jun 18, 2003 06:52 AM
ITR9788
May 30, 2003 05:20 PM
