Custom Fuel Cell and Radiator Modification
Old Aug 11, 2012 | 05:16 PM
DelSolMarine's Avatar
Default Custom Fuel Cell and Radiator Modification
So I have had a lot of issues with fuel with my Turbo setup with E85. Between Fuel pressure dropping and only having a 11 gallon tank I decid to make everything simplified with external pumps and a gravity fed 15 gallon fuel cell. I drive the car very often I like the daily drivability factor of the car.
I have also added some photos of the modifications taking place for my radiator. The radiator is being turned sideways and pulled forward in order to retain the spal puller fan setup and actually putting an intake on the turbo inlet. Pulling the radiator setup forward like this cleared a good 2 inches of clearance away from the turbo manifold which should help with heatsoak even though this car doesnt go over 194 it will only help... particularly at idle...
Hope you enjoy the pictures. River City Speed in Richmond Virginia did the work.
Old Aug 11, 2012 | 05:45 PM
99electron_blue_si's Avatar
Default Re: Custom Fuel Cell and Radiator Modification
How do you plan to bleed that radiator?
Old Aug 11, 2012 | 05:53 PM
the end tanks are being modified...
Old Sep 11, 2012 | 07:05 PM
couple random updates on this project... hoping for dyno results soon... the exhaust pictures are new because the two panels were just added...
Old Sep 12, 2012 | 09:09 AM
13g-crx's Avatar
Whats weird is I dont hate that exhaust. I usually hate stuff like that.
Old Sep 12, 2012 | 09:12 AM
Muckman's Avatar
Moderator in Chief
Because its done nicely. :tup:
Old Sep 12, 2012 | 09:13 AM
Cole D's Avatar
Did you consider going with a dual pass radiator?
Old Sep 12, 2012 | 09:21 AM
Muckman's Avatar
Moderator in Chief
It is a dual pass radiator now. He flipped it on its side and reworked the end tanks.
Old Sep 12, 2012 | 09:48 AM
sleepencivic's Avatar
Any pics of the radiator installed? Seen this car in person getting tuned, clean set-up.
Old Sep 12, 2012 | 12:11 PM
Yes, the dual pass setup is now in place which should make the cooling much more efficient. The car did not go over 196 on the dyno with the original setup (even without a fan shroud for the spal fan). I still have not added a shroud yet but hopefully the temps will stay closer to 190 now with the dual pass configuration and the fact that the fan is a little further away from the manifold than before.
No other pictures of the radiator other than the stuff I have already posted here
Thanks for the compliments on the exhaust. I wanted something different.
Old Sep 12, 2012 | 12:45 PM
cruizinmax's Avatar
I like it. I have heard that you should never use a 90* fitting on the low pressure side of the fuel pump though. Fuel pumps aren't efficient at pulling fuel and you want little/no restriction on the low pressure side.
Old Sep 12, 2012 | 01:42 PM
tepid1's Avatar
The Bosch 044 pulls fuel very well compared to the Aeromotive A1000 and alike. It won't be an issue.
Old Sep 12, 2012 | 04:22 PM
yea i had this same concern myself but the bosch pumps are very efficient... i shouldnt have any problems... the fuel doesnt have to be lifted up like an intank setup because the fuel is sitting on top of the pumps so thats another benefit...
Old Sep 12, 2012 | 06:02 PM
cruizinmax's Avatar
Cool, that's good to know. I'm sure this setup should take you to the next level.
Old Sep 12, 2012 | 06:15 PM
tepid1's Avatar
Right, there is enough head pressure from the fuel.
Old Sep 12, 2012 | 06:44 PM
.dave's Avatar
i HAS questions ?
Nice work. Get that exhaust manifold coated.
Old Oct 5, 2012 | 11:08 AM
Cole D's Avatar
I see you have your a/c compressor still installed any plans to run a/c? If so what condensor do you plan on running?
Old Oct 6, 2012 | 04:33 AM
zedron's Avatar
Whats weird is that I usually hate all Del Sols, but I actually like this one. Nice work.
Old Oct 6, 2012 | 05:53 AM
secretcitizen's Avatar
Nicely done!
on the exhaust
Tootsie7944
Feb 9, 2012 01:56 PM
Project99EK
Nov 5, 2006 07:33 AM
delslowh23
Mar 14, 2004 03:30 PM
QCKGSR
Sep 11, 2003 09:05 PM
d mafia
Jan 19, 2002 06:26 PM
