CTR cams and Turbo
Old Sep 10, 2003 | 10:37 PM
Fuzion's Avatar
Default CTR cams and Turbo
Is CTRcams a better choice over ITR/GSR cams for turbo app?
What companies make a cam str8 for Turbo applications?
How agressive is the CTR cams on boosted motors?
Old Sep 10, 2003 | 11:16 PM
Charbon Sty's Avatar
Default Re: CTR cams and Turbo (Fuzion)
CTR cams are recommended for n/a applications. i wouldnt see the point in using it with a turbo application. you would be better off with the skunk2 turbo cams
Old Sep 11, 2003 | 01:13 AM
Unsung's Avatar
Default Re: CTR cams and Turbo (kelsonmassif)
I'm in a similar situation. I started building my car mildy for N/A but now am going FI. Is it a big deal to keep the R cams in there or should I swap them out? I have adj cam gears to dial out overlap if that matters. Sorry to jack thread, just trying to shed some light on the R cam'd boosted cars.
Old Sep 11, 2003 | 03:37 AM
ekb18c's Avatar
try doing a search, it's been covered many times.
HTH
https://honda-tech.com/zerothread?id=192567
https://honda-tech.com/zerothread?id=528603
here are just a few
Modified by ekb18c at 4:54 AM 9/11/2003
Old Sep 11, 2003 | 10:27 AM
Fuzion's Avatar
Default Re: CTR cams and Turbo (ekb18c)
ok first this is my thread..lol...but i said CTR not ITR, he asked for itr...no tme..so since you are giving out advice....care to lend me sum on the ctr and turbo set-ups. good or decision or not?.
Old Sep 11, 2003 | 11:21 AM
STEALTHMODECOUPE's Avatar
CTR and ITR cams are identical unless you have 00-01 CTR cams then the intake cam has slightly higher duration .3 i think..from what i hear and have read gsr cams are the way to go when going FI..thats if you want use OEM cams
adaM
Old Sep 11, 2003 | 11:24 AM
Unsung's Avatar
Default Re: CTR cams and Turbo (STEALTHMODECOUPE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STEALTHMODECOUPE &raquo;</TD></TR><TR><TD CLASS="quote">CTR and ITR cams are identical </TD></TR></TABLE>
Pretty damn close, and I'm using CTR anyway, you assumed I was using ITR. I've always heard GSR's are the best for boost for OEM cams.
BTW&gt; Those threads are good... I think i'll keep the R cams.
Old Sep 11, 2003 | 02:38 PM
MiraiZ's Avatar
Default Re: CTR cams and Turbo (Unsung EM1)
CTR cams if tuned right!
Old Sep 11, 2003 | 03:55 PM
ekb18c's Avatar
Why do people get so mad when other says search?
I also provided links to other discussions about type r cams.
Listen! Type r cams are good, much better than regular Gsr cams, IMO.
I had gsr cams in and ran it for about 6 months. Then I put Type r cams in and off the bat I noticed a difference. My assometer told me it was faster. Sorry I do not have any dyno plots of before and after. I only have dyno plots with type r cams. People talk about blah blah, overlap this and overlap that... Blah. People should be talking about duration on turbo cars.
Old Sep 11, 2003 | 03:59 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb18c &raquo;</TD></TR><TR><TD CLASS="quote">Why do people get so mad when other says search?
I had gsr cams in and ran it for about 6 months. Then I put Type r cams in and off the bat I noticed a difference. My assometer told me it was faster. Sorry I do not have any dyno plots of before and after. I only have dyno plots with type r cams. People talk about blah blah, overlap this and overlap that... Blah. People should be talking about duration on turbo cars. </TD></TR></TABLE>
I agree with Colin here! I have recently been told by a VERY VERY knowledgable engine builder and head porter that Type R cams are very good but not only him but another very well respected Tuner and engine builder with a Major race team said the Type R cams had tested very well. I plan to swap my Si Cams for some Type R cams to see if there is a difference
Old Sep 11, 2003 | 04:09 PM
Fuzion's Avatar
Default Re: CTR cams and Turbo (Boostfed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostfed &raquo;</TD></TR><TR><TD CLASS="quote">
I agree with Colin here! I have recently been told by a VERY VERY knowledgable engine builder and head porter that Type R cams are very good but not only him but another very well respected Tuner and engine builder with a Major race team said the Type R cams had tested very well. I plan to swap my Si Cams for some Type R cams to see if there is a difference</TD></TR></TABLE>
What about CTR cams, any info on those?
Old Sep 11, 2003 | 04:11 PM
ekb18c's Avatar
What year CTR cams do you have?
Old Sep 11, 2003 | 04:17 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fuzion &raquo;</TD></TR><TR><TD CLASS="quote">
What about CTR cams, any info on those?</TD></TR></TABLE>
I was specifically told ITR cams and I figured he meant 97-98 ITR specs adn not the 2000-2001 spec which the Intake is same as CTR many have stated. The tthing is the CTR cam has 3 degrees more duration that an ITR intake cam which doesn't seem like alot BUT the opening and closing events are very different also. I don;t have REAL DATA myself, just my tuner swapped out his GSR to Type R cams with no gains he said, I don;t know how much was done when he swapped them out such as additional tuning, I don;'t think he retuned the gears which would make a BIG difference I feel.
Old Sep 11, 2003 | 04:21 PM
ekb18c's Avatar
Dude.. Change your Avatar. It's really unpleasant to look at. Only 2 Avatar have really annoyed me. Your's and Afropuff's. Afropuff was banned from Honda Tech. *hint* hint*
If the avatar is you, I'm so sorry!
Old Sep 11, 2003 | 07:46 PM
JDMs1eeper's Avatar
gsr cams or stock
Old Sep 11, 2003 | 07:55 PM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb18c &raquo;</TD></TR><TR><TD CLASS="quote">Dude.. Change your Avatar. It's really unpleasant to look at. Only 2 Avatar have really annoyed me. Your's and Afropuff's. Afropuff was banned from Honda Tech. *hint* hint*
If the avatar is you, I'm so sorry! </TD></TR></TABLE>
Man that is Beetlejuice from Howard Stern one ******* looking mf'er! And I COULDN'T STAND Afropuff!!!! I hated his Avatar too I thought I was the only one. Was that him in it? Cocky ***!
Old Sep 11, 2003 | 07:56 PM
Boostfed's Avatar
New User
Default Re: CTR cams and Turbo (Typesi2nv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Typesi2nv &raquo;</TD></TR><TR><TD CLASS="quote">gsr cams or stock </TD></TR></TABLE>
Uh GSR cams are stock.
Old Sep 11, 2003 | 08:07 PM
1fstevo's Avatar
New User
Listen! Type r cams are good, much better than regular Gsr cams, IMO. </TD></TR></TABLE>
That is why I have never replied anything on his posts. I didn't like the way he ask for answers with some " you have to reply attitude". He has been asking all kinds of dreamful questions with limited parts and fabrication on his setup in FI and EG forum.
Dude, if you want answer, be nice and not everyone will tell you how to go fast.
First get rid of your 440cc injectors to achieve above 450+ HP.
Old Sep 11, 2003 | 08:21 PM
Full-Race Henry's Avatar
Default Re: CTR cams and Turbo (Evo Hybrid)
has anyone had any experience with any type of turbo cams. it seems like everyone just uses stock oem cams. how do the skunk2 turbo cams perform?? anyone know??
Old Sep 11, 2003 | 08:24 PM
Boostfed's Avatar
New User
Default Re: CTR cams and Turbo (EF8_Fan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF8_Fan &raquo;</TD></TR><TR><TD CLASS="quote">has anyone had any experience with any type of turbo cams. it seems like everyone just uses stock oem cams. how do the skunk2 turbo cams perform?? anyone know??</TD></TR></TABLE>
I spoke to Skunk when these cams were first released, these are for a low boost street app only , anything with a small or medium size turbo running 15psi or less and 8k rpm or less. The cams are actually less aggressive than stock Si cams, they are similar to Automatic JDM VTEC cams, low lift and short duration. I called and told them my goal was 550whp or so with 25psi and running up to 9500 rpms, they said this cam is not for me and will definately start dropping off in power above 8000rpm. i was sa to hear since I waited awhile for their cams. Stock cams have proven to be the best but Brad aka MAX_CFM states he has a turbo cam that makes POWER!
Old Feb 24, 2004 | 12:05 AM
1SlowSi's Avatar
If i just stick with the GSR cams can you just drop it in and be fine without messing with the cam gears? or should you tune a little bit with it. I understand that its recommended with the CTR cams.
big head
Oct 11, 2005 06:19 PM
spooledex
May 29, 2004 10:41 AM
Mr Aryan
May 7, 2004 06:44 AM
mitch83
Feb 24, 2004 01:54 AM
turtle-eg
Nov 26, 2003 02:26 PM
