CTR cams and boost?
Old Jan 31, 2004 | 10:24 AM
Trak_Day's Avatar
New User
Default CTR cams and boost?
I have heard some good things but i would like to hear other opinions. I have a built b18c1 and am looking at 450whp on pump gas. Any one have experience with these cams on a high hp app?
I was told yesterday that a guy gained 21whp up top. Just wondeing wqhat you guys think about this
Old Jan 31, 2004 | 10:28 AM
TheShodan's Avatar
Moderator
Believe it or not... Keep the GS-R cams if you have them... Perfect.
Old Jan 31, 2004 | 10:35 AM
baphomet's Avatar
Default Re: CTR cams and boost? (DroppedGSR)
here is boostfed's post https://honda-tech.com/zerothread?id=704660
ITR cams
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostfed &raquo;</TD></TR><TR><TD CLASS="quote"> the cams were good for 20 whp and 10 ft-lbs just by themselves</TD></TR></TABLE>
Old Jan 31, 2004 | 11:34 AM
Trak_Day's Avatar
New User
Ok, thanks for that link! now correct me if i am wrong but 2001+ ITR cams are the same as CTR cams, correct? Also, does anyone know of a reputable dealer for these cams?
Thanks for the info so far! I can wait to get those babies in!
Old Jan 31, 2004 | 11:39 AM
baphomet's Avatar
Default Re: (DroppedGSR)
I think they are really really close. I don't know much about OEM cam specs off the top of my head - look in the all motor forum.
Old Jan 31, 2004 | 11:41 AM
baphomet's Avatar
Default Re: (slashDEVslashNULL)
BTW, be careful when you buy cams, there have been a lot of fake ones floating around.
Old Jan 31, 2004 | 01:31 PM
Rod.'s Avatar
I have some real ctr cams for sale.
Old Jan 31, 2004 | 02:34 PM
99blackcivicSi's Avatar
Default Re: (redturbocivic)
I think they were recommended for terrys car because he is running a B16 bottem end and he has no *** down low that is why they were recommened for his car. but GSR cams will do you fine.
Old Jan 31, 2004 | 02:54 PM
reaction360's Avatar
Default Re: (99blackcivicSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99blackcivicSi &raquo;</TD></TR><TR><TD CLASS="quote">I think they were recommended for terrys car because he is running a B16 bottem end and he has no *** down low that is why they were recommened for his car. but GSR cams will do you fine.</TD></TR></TABLE>
i got a built b16 bottom end. wth a gsr head and gsr cams..., would i be better off getting some ctr cams then? or keeping the gsr cams? cuz i kno the gsr cams are good for boost.
Old Jan 31, 2004 | 03:12 PM
Trak_Day's Avatar
New User
From what i understand it is a good idea to change out the intake cam when running a built head. I am going to get the intake cam for sure, just deciding on whether i want both or not, i may even get the ITR cams since there cheaper. I will definately be posting dynos when installed!
EDIT: alright, now i think i may have had a brain fart but someone please remind me which of the 2 cams is best to switch out, Head is still pounding from last night. Thanks
Old Jan 31, 2004 | 03:14 PM
Jaesung's Avatar
keep us informed.
Old Jan 31, 2004 | 09:39 PM
Rusty Shackleferd's Avatar
Default Re: (Jaesung)
Im running a ctr intake cam and a gsr ex exaust, and my motor loves them, ill be rollin in 3rd gear i'll step into it and when it gets to 8000 it breaks the **** loose and goes strait to the limiter and thats on D/Radials. I have many close friends with turbo cars that run gsr cams with good results, but they dont make power above 8500, where in my car that just the beginning.
It does pretty much the same thing as an N/A motor does when you put a bigger cam in it.
MAKES MORE UPPER END POWER.....
Old Jan 31, 2004 | 09:41 PM
Trak_Day's Avatar
New User
That is the kind of info i was lookng for! I am thinking i am only going to replace the intake cam!!! thanks man
Old Jan 31, 2004 | 09:48 PM
Chrome Pipes's Avatar
Default Re: (10secondbeast16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 10secondbeast16 &raquo;</TD></TR><TR><TD CLASS="quote">Im running a ctr intake cam and a gsr ex exaust, and my motor loves them, ill be rollin in 3rd gear i'll step into it and when it gets to 8000 it breaks the **** loose and goes strait to the limiter and thats on D/Radials. I have many close friends with turbo cars that run gsr cams with good results, but they dont make power above 8500, where in my car that just the beginning.
MAKES MORE UPPER END POWER.....</TD></TR></TABLE>
I know this has been beaten to death, but do you really need the ITR exhaust cam? I have a CTR intake cam sitting on my shelf right now, but I would think it makes more sense to put in a type-r exhaust cam as well. Does it really matter if you have the exhaust cam or not?
Old Jan 31, 2004 | 11:47 PM
Kataku2K3's Avatar
Default Re: (Chrome Pipes)
Just for your info, not that it's a big deal... The 2000+ ITR IN cams have the same profile to that of the CTR's...
Old Feb 1, 2004 | 12:17 AM
gsr itr ctr 00si exaust cams are very simalar(from specs ive seen and friends ive talked to) But id check to be sure. I think the most bang for the buck is on the intake side. But im only speaking from personal experiences. I think the gsr exaust cam will work fine when using a typical t3t4 turbo because it can only flow so much cfm. i dont think using a bigger exaust cam is going to help much when your turbo cant keep up with the flow demands. I want to build a 1600cc motor with a t66 and some huge cams, taking the info ive learned from my current set up super sizing the cams, turbo, head ports, in&ex manifolds should make for a high rpm and high hp beast and hopefully gives me 9 second b16 bragging rights. But for now its just a dream.
Old Feb 1, 2004 | 01:28 AM
ninesecteg's Avatar
the ctr and 2001 itr cams are the same, all years below that in itr have 3 degrees less duration in the int cam. the exhaust are identical. the itr cams seem to be able to pull the torque up to about 8500 easier before it falls where the gsr's start to fall at 8000.
Old Feb 1, 2004 | 08:26 AM
Default Re: (ninesecteg)
Following cam measured with 0mm of lift:
Civic Si(1999 Spec)
Int-265 dur. / 10.5mm lift
Exh-267 dur. / 9.6mm lift
Integra GS-R
Int-274 dur. / 10.7mm lift
Exh-276 dur. / 9.6mm lift
Civic Type-R And Integra Type-R(Integra Type R 2000/01 Spec)
Int-278 dur. / 11.5mm lift
Exh-280 dur. / 10.5mm lift
Taken from here:
http://www.clubcivic.com/showthread/t-6646.html
From the looks of it, it seems like the exhaust specs aren't that close..
Old Feb 1, 2004 | 12:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chrome Pipes &raquo;</TD></TR><TR><TD CLASS="quote">Following cam measured with 0mm of lift:
Civic Si(1999 Spec)
Integra GS-R
Taken from here:
yea, that 01 spec exause cam is alot bigger, what the specs on first gen itr cams?
Old Feb 1, 2004 | 12:07 PM
len's Avatar
len
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DroppedGSR &raquo;</TD></TR><TR><TD CLASS="quote">Also, does anyone know of a reputable dealer for these cams?</TD></TR></TABLE>
If you're looking for a new set give me a buzz during normal business hours. I hope I'm reputable enough. Hehe.
From reading numerous threads, the general rule of thumb that I've noticed in those threads is this:
If you are a running a modified head with higher airflow, the extra lift and duration on the ITR camshafts is not necessary.
But if you have a stock head, you will benefit from the camshafts more.
EJ8 GSR-T
Feb 20, 2006 09:42 PM
compwc18
May 22, 2005 05:05 PM
rev2ninetyper
Jul 21, 2004 04:08 AM
patdemps
Jul 17, 2003 08:07 PM
B00ST2nR
Apr 17, 2002 01:26 PM
