ct26 b16a g2
Anybody tried this setup. b16a g2 8.5:1 compression forged pistons and rods. blockgaurd, valves, springs, retainers, im gunna start small with the 8 psi that the wastegate is set to. and see where it goes from there.
jsut wondering if anybody has used toyota turbos on hondas and what luck they've had
not 100% true. Coming form Mr2's which use the CT26 (as well as the MKIII supras) the Mr2 version of the turbo uses a diffrent flange all togather mitsubishi if I'm not mistaken the 7CM2. You have to have an adapter plate to put a T3 flanged turbo on it. No 100% sure what the supra version has. Just make sure it's the right one.
Mitch
Mitch
the point made was that a turbocharger is a turbocharger. the question was not about flanges, it was about whether a turbocharger from a specific car was going to be a good match to a specific engine. further, the question was not even whether it was well matched, but whether or not a "toyota" turbo would be compatible with a honda engine.
what difference does a flange make?
Well the question was about matching. since a supra motor is a slight bigger motor then the b16. i figured anyone would understand i was asking if anybody has used it on a b16 before so i know how its gunna spool. maybe i said i wrong. so now u know
