crower 404's and boost???
Old May 5, 2004 | 01:15 AM
sPaRk'iT's Avatar
Default crower 404's and boost???
I have a b20 motor, stock, but im boosting very very soon, i found a deal on a built LS head with 404's and i was wondering would it be safe to run 404's with t3/t4, any pro's and con's or experince? thanks
Old May 5, 2004 | 07:48 AM
TURBODC4TEG's Avatar
Default Re: crower 404's and boost??? (sPaRk'iT)
no if u want to a run a cam then stock or crower 420t -turbo cam
Old May 5, 2004 | 08:39 AM
sPaRk'iT's Avatar
Default Re: crower 404's and boost??? (JDMDC4TURBO)
so it would be a bad idea then??? anyone else??
Old May 5, 2004 | 09:57 AM
bogus_ek's Avatar
yes it would.... check crower.com for more iinfo... there's a reason for why they would make a cam specifically for turbo...
Old May 6, 2004 | 11:24 AM
sPaRk'iT's Avatar
Default Re: crower 404's and boost??? (bogus)
anybody wanna trade? 404 for 402T??
Old May 6, 2004 | 03:33 PM
NVturbo's Avatar
O.G. triple O.G.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sPaRk'iT &raquo;</TD></TR><TR><TD CLASS="quote">I have a b20 motor, stock, but im boosting very very soon, i found a deal on a built LS head with 404's and i was wondering would it be safe to run 404's with t3/t4, any pro's and con's or experince? thanks</TD></TR></TABLE>
I used to run the 403's in my turbo setup and the idling sucked. It would die every now and then at a stop......Traded them for stock units and my ride idled better but lost top-end power...(That's why they invented boost controllers.....rite?!!!)
Old May 6, 2004 | 03:48 PM
boosted92's Avatar
Default Re: crower 404's and boost??? (NVturbo)
Stock LS cams: 185/187 @ .050, .395/.380 lift
Crower 404's: 216/218 @ .050, .446 .432 lift
Duration is less radical than stock VTEC cams but with more lift. They seem well suited to turbo apps if you're going to spin the motor hard.
Old May 6, 2004 | 04:20 PM
sPaRk'iT's Avatar
Default Re: crower 404's and boost??? (boosted92)
bump, i need more info.
Old May 6, 2004 | 05:08 PM
boosted92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sPaRk'iT &raquo;</TD></TR><TR><TD CLASS="quote">bump, i need more info.</TD></TR></TABLE>
As long as you have a good ported head and good valvetrain stuff I can't see anything wrong with 404's. HKS makes cams specifically for turbo motors tha have a fair bit more duration than the crower 404's.
Old May 6, 2004 | 06:44 PM
SoulEdge's Avatar
I agree, everyone praises the gsr cam for boost but then shoots down anything but a "turbo" cam on an ls without looking at the specs. Something to keep in mind though is these cams are make the most power in the upper rpm range and an uported ls head is dying after about 6k.
Old May 10, 2004 | 02:10 AM
sPaRk'iT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 &raquo;</TD></TR><TR><TD CLASS="quote">
As long as you have a good ported head and good valvetrain stuff I can't see anything wrong with 404's. HKS makes cams specifically for turbo motors tha have a fair bit more duration than the crower 404's.</TD></TR></TABLE>
So it is possible too then? i can use them??
Old May 10, 2004 | 12:46 PM
sPaRk'iT's Avatar
ttt
Old May 10, 2004 | 12:51 PM
boosted92's Avatar
So it is possible too then? i can use them??</TD></TR></TABLE>
Honestly I don't see why not.
HKS 272: 272 Advertised Duration, 9.25MM lift
Crowers: 249/251 Advertised Duration, 11.32/10.97MM lift
Less duration and more lift than the HKS cams. Isn't that what everyone pimps for turbo cams around here? Keep in mind that crower 404's are still milder than all the stock VTEC cams in terms of duration, just with more lift. People are making great power on stock VTEC cams, so why not the 404's? Stop second guessing yourself, run the 404's they'll work great.
Old May 10, 2004 | 08:04 PM
sPaRk'iT's Avatar
hhmm..ok i see. I guess ill just go ahead and try it, and see how it runs.
Old May 11, 2004 | 10:50 AM
sPaRk'iT's Avatar
buMp
Old May 18, 2004 | 05:24 PM
B18Tahtaras's Avatar
I've heard great things about thoes cams and turbo setups... The lobe profile on the cams is a medium that gives improvements in both N/A and F/I setups. However, if you get a good cam that is specifically designed for a Turbo motor... you'll notice a big difference in spooling time, and pull.
However, there is alot to do with cam profiling, i've studied this for a couple years now... Feel free to ask me questions.
Old May 18, 2004 | 06:03 PM
Joseph Davis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 &raquo;</TD></TR><TR><TD CLASS="quote">Stock LS cams: 185/187 @ .050, .395/.380 lift
Duration is less radical than stock VTEC cams but with more lift. They seem well suited to turbo apps if you're going to spin the motor hard.</TD></TR></TABLE>
Here's for thinking
My only concern would be LSA between the cams, you can probably dial it out with a set of cam gears and - viola! Better idle quality.
Ov3rr3vd3ls0l
Apr 29, 2008 02:17 PM
00situner
Jan 31, 2006 02:54 PM
chewybalooy
Jan 26, 2006 08:21 PM
yusoslo
Mar 28, 2004 09:14 AM
#417R
Dec 11, 2002 11:15 PM
