Crome or Uberdata? and what do i need
Old Oct 18, 2005 | 05:32 PM
  #26
93turbo16's Avatar
Only P30 is really supported in crome, P72 doesn't even have RTP and junk without adding them. You basically have to just start with the P30 map and go from there.
Old Oct 18, 2005 | 05:44 PM
  #27
BlueShadow's Avatar
Default Re: (Soccerking3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">Also if you purchase the pro version what happens when there is a new updated version of crome? do you have to keep the older version or what? My uberdata has been giving me **** recently and i know crome will work so imight shell out the cash into something i know will work w/o glitches and major problems </TD></TR></TABLE>
John Cui sends you the info reg string that you input into Crome. Make sure that you are inputting this reg string on the computer you are going to be using CromePRO from. I dont know if it's against Johns TOS, but I have 2 different versons of CromeFREE and to upgrade them to PRO all I had to do was enter the reg string into both. So I have two different versions of CromePRO running on my laptop.
Old Oct 18, 2005 | 06:16 PM
  #28
Pay2play killa's Avatar
Default Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">Only P30 is really supported in crome, P72 doesn't even have RTP and junk without adding them. You basically have to just start with the P30 map and go from there. </TD></TR></TABLE>
you use either p30 or p72 CODE BASE on the roms; has nothing to do with fuel maps.
you can add yours in there or make your own. crome will support just about every obd1 ecu as they all run pretty much the same code base
Old Oct 18, 2005 | 06:36 PM
  #29
93turbo16's Avatar
Default Re: (Pay2play killa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pay2play killa &raquo;</TD></TR><TR><TD CLASS="quote">
you can add yours in there or make your own. crome will support just about every obd1 ecu as they all run pretty much the same code base</TD></TR></TABLE>
I know it has nothing to do with the fuel maps, they are completely different take a look at the scalars. You just can't add the same plugins to each base rom.
Old Oct 18, 2005 | 06:46 PM
  #30
Soccerking3000's Avatar
so i can run p30 code base on my p28?
Old Oct 18, 2005 | 06:56 PM
  #31
93turbo16's Avatar
of course. That is how you get the boost tables for a P28. You can copy and paste them, but it will need tuning, since the scalars are different. But you have to remember, you are really opening it in P30 code anyway in crome, you just are using P28 values instead.
Old Oct 18, 2005 | 07:28 PM
  #32
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">so i can run p30 code base on my p28?</TD></TR></TABLE>
yes i am/have/will
projectxspeed
Apr 15, 2005 08:19 AM
Touge Tuning
Dec 10, 2004 12:47 PM
92civiclsb18a
Jun 30, 2004 08:41 PM
Mr.Saturn
Apr 5, 2003 09:43 PM
ZERO COOL
Jul 28, 2002 12:22 PM
