Crankcase breather options
Old Jul 15, 2017 | 08:21 AM
Morgan Reitz's Avatar
Icon5 Crankcase breather options
On honda engines, there's the pcv valve that runs to the intake manifold, and there's the breather that runs from the intake piping. The breather is supposed to allow pressure back into the crankcase because the pcv will be sucking the pressure out. This seems good for naturally aspirated engines but with forced induction wouldn't the breather tube be causing excessive crankcase pressure? Would it be best to replace the breather tube with a small filter or leave it as is? Any ideas?
Old Jul 16, 2017 | 07:40 AM
Sprockets's Avatar
Default Re: Crankcase breather options
There are a dozens of threads about breather setups, so search and be prepared to do some reading. As for the hose that normally goes to the intake piping, if you want to keep that as stock as possible, it should be moved to the intake before the turbo. That's the way it was on my street legal Greddy kit years ago. I didn't like this because oil vapors would get into the turbo and intercooler.
Old Jul 25, 2017 | 09:21 AM
rice a roni's Avatar
People usually use catch cans and vent to atmosphere or use a catch can and have vacuum pull the gasses back into the intake via the intake arm on the compressor housing. There were a couple good reads I found when I was researching on honda-tech.
Old Jul 25, 2017 | 10:36 AM
TheShodan's Avatar
Moderator
That was simply from the crank case pressure itself, it wasn't the hose's fault. It just meant that you didn't change it much from the factory setup is all.
Old Jul 16, 2019 | 06:45 PM
XelginX's Avatar
Sorry to beat on a old thread.. I found a old nrg catch can I never installed. Its a sealed can with 2 ports. My question is. If I want to use the 2 ports on the back of the block would i need to drill and tap my can to vent it? Should i just toss that catch can because its old junk anyway? It will be a turbo set up if that matters.
Old Jul 16, 2019 | 07:44 PM
Txdragon's Avatar
Don't use a non-vented can on a turbo. I found out the hard way recently..
Old Jul 17, 2019 | 03:40 AM
Autoworks's Avatar
Toss it
Old Jul 17, 2019 | 08:46 PM
TheShodan's Avatar
Moderator
See the sticky in grey at top of forum
Momentum
Oct 13, 2011 12:54 PM
Oknoe.
Jun 2, 2010 06:07 PM
Killersohc
Nov 17, 2005 05:05 PM
Hyaboosta
Mar 16, 2005 06:29 AM
blowncivichb
Apr 10, 2002 08:22 AM
