Crank Fluctuation Sensor
Old Nov 9, 2001 | 07:59 AM
rtype11's Avatar
Default Crank Fluctuation Sensor
Bulit a 95 LS block, a GSR oil pump, the 96ls pump has a fitting for the CFS, the GSR doesnt, what do GSR's use for CFSensor??? - I cant retrofit this sensor to the pump as the 96 pump has a special locating pin for it. Is the knock sensor in the GSR made to detect misfire just like the cfs in the LS motor????????????
Old Nov 9, 2001 | 08:09 AM
Incognito's Avatar
Default Re: Crank Fluctuation Sensor (rtype11)
The CFS bolts onto the block and reads a timing wheel thing on the crank. It's not on any pre-1996 blocks, GSR or LS. Not sure if you can retrofit it. The sensor doesn't do much. From what I know, it's for start-up. That sensor tells the ECU which cylinder to fire first (kinda let's the ECU know where the crank last stopped at). I have run a '95 GSR motor in a '96 GSR before, and left that sensor off. It does keep the check engine light on, but does nothing affecting performance.
The knock sensor detects knock. It's basically a little microphone. You can tap a hole and fit this onto an LS block, by the oil filter.
Old Nov 9, 2001 | 08:27 AM
VTC_CiViC's Avatar
Default Re: Crank Fluctuation Sensor (Incognito)
How good is the factory knock sensor really? How far can it/does it retard the timing?
Old Nov 9, 2001 | 10:05 AM
rtype11's Avatar
tanX, everything I have is 96 up, but now I dont have either knock or CFS, CFS is not just for engine start, it is actually what will trigger your 71 - 74 CEL. I think I may want it still but I have upgraded oiling system where the locating pin for CFS sensor is supposed to be on a 96 LS.
raverx3m
Engine Management and Tuning
Aug 5, 2021 07:50 PM
mannydhanju
Jun 21, 2009 08:55 PM
jlfrnce
Apr 19, 2007 05:51 AM
Greasemonkey
Oct 19, 2004 03:22 PM
CM-R
Mar 29, 2002 12:34 AM
