knock sensor compatibility
Old Jun 21, 2009 | 02:34 AM
mannydhanju's Avatar
Default knock sensor compatibility
I broke my knock sensor and am wondering are ls/gs/rs knock sensors compatible with my 95 gsr. I have a 1990 b18a1 knock sensor that i got at a pick n pull will it work with my 95 gsr, if not which ones will work because napa and kragen stores want $200 or so for it.
Old Jun 21, 2009 | 08:13 AM
ek-g6's Avatar
Default Re: knock sensor compatibility
All Honda knock sensor should work, but not the sensors from newer cars like rsx or em2 civic, but I didn't know Ls came with knock sensors, from what I've seen they came in b series vtec engine and d16y8 and many luxury cars like the vigor or legend.
Old Jun 21, 2009 | 05:07 PM
civicgsr499's Avatar
just to let u know they never made a knock sensor for the ls. just gsr/other vtec motors
Old Jun 21, 2009 | 08:55 PM
TheWhopper's Avatar
I took a knock sensor off from an 92 LS block just recently.
Can you take a picture of the knock sensor? Depending on where it broke you may be able to simply solder the wires back on and crazy glue the plastic cap. I did..worked perfectly.
You can use a soldering iron and a hard piece of plastic to re-attach the broken plastic cap. Repaired a few sensors and solenoids that way...
gabrielsousa
Nov 4, 2015 04:12 PM
ls weez
Jun 10, 2006 02:01 PM
DR. ON POINT
Dec 12, 2001 12:26 PM
