crank case question
Old Oct 11, 2001 | 07:28 AM
  #26
Mr. Vapor's Avatar
Default Re: crank case question (TurboInteg95)
so i am about to cut a hole in my BOV intake piping to fit this piece, is this correct? drill a hole, slash cut the tube and stick it in? I wont leak boost if i do this will I?
Old Oct 11, 2001 | 07:46 AM
  #27
bigTom's Avatar
Default Re: crank case question (NYb16)
hell no! dont cut a hole in it! my opinion is just have a breather... it works... u dont want all that garbage going back into ur motor... whatever comes out of ur breather that is...
and as far as t.o.o.'s fraud *** web-site... i wouldnt trust anything he says
Old Oct 11, 2001 | 07:55 AM
  #28
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: crank case question (ek9t)
00SilverLS Not again?
We talked about this just the other day. There is no way you could have found this topic even if you did a search, so you are excused. https://honda-tech.com/zerothread?id=75695
Old Oct 11, 2001 | 10:18 AM
  #29
rtype11's Avatar
Default Re: crank case question (Arturbo)
just food for thought if you really want to evacuate crank case vapour and create a vacuum in there do what nascar and top fuellers do, plumb that line from the valve cover into one of your primaries or downtube. I suggest this for race only and I would put an oil separator inbetween, this will give you some power also.
cheers.
no flames please, or flamers
[Modified by rtype11, 11:19 AM 10/11/2001]
[Modified by rtype11, 11:20 AM 10/11/2001]
Old Oct 11, 2001 | 10:55 AM
  #30
JM Performance's Avatar
If you cut a hole, it needs to be preturbo. IE, between the turbo and the air filter.
Old Oct 11, 2001 | 04:53 PM
  #31
quikrpm'z's Avatar
Default Re: crank case question (00SilverLS)
im gonna run my car through emmisions soon. I've been told that the little filters or a catch can would not pass. So is it most peoples oppinion that running the lines back to the intake or, pre-turbo intake like 00Silver said, is a bad idea?
Old Oct 11, 2001 | 05:54 PM
  #32
Default Re: crank case question (quikrpm1)
the catch can should pass. Your still running the crank case vapors back through the system. its actually cleaner this way.
but, yeah, if you want, you could just disconnect it for emissions.
Old Oct 12, 2001 | 01:38 PM
  #33
Mr. Vapor's Avatar
ok, so my IAT sensor.........GSRs plug into the mainfold, however on the Si, it goes into the stock air filter box, but now that i have a turbo, where should i plug it in to read the correct temp?
E.Honda
14
Dec 16, 2005 06:34 PM
EG2Driver
Nov 5, 2005 09:27 PM
Louie
Sep 11, 2002 06:02 AM
zojirushi
Dec 15, 2001 12:37 AM
Purelude
Jun 22, 2001 08:51 PM
