CP ring gap question
Old Jan 21, 2004 | 02:48 PM
maddog20's Avatar
Default CP ring gap question
What ring gaps to use on CP Pistons on d16 w/ .020 overbore. I called Cp and they told me .016 for the top and .018 for the 2nd ring and oil control ring so it doesn't over lap?
After a search I saw most did 18 on the top and 16 on the bottom? Any suggestions?
Old Jan 21, 2004 | 02:55 PM
99B16Si's Avatar
the top ring gap should be left open about .001-.002 more than the second ring due to the higher heat expansion of the top ring
Old Jan 21, 2004 | 03:14 PM
maddog20's Avatar
Default Re: (99B16Si)
hmm thats cazy! I wonder why they gave me those specs?
I guess they don't like me?
Old Jan 21, 2004 | 03:25 PM
99B16Si's Avatar
ring gap will also vary from the power output of a motor
less power=less heat=less gap (to a certain extent)
Old Jan 21, 2004 | 04:00 PM
PrecisionH23a's Avatar
Default Re: CP ring gap question (maddog20)
How much boost are you planning on running?
Old Jan 21, 2004 | 04:08 PM
Nextelbuddy's Avatar
Default Re: CP ring gap question (PrecisionH23a)
sorry to hijack your thread but i didnt want to start a whoe new thread on a similar quetion.
i have JE pistons 81mm bore 9:1 compression going into a 2001 b18c1. i just got my new JE piston rings that i ordered from JE last week.
what should i gap the rings to? any body in here have the same setup and can tell me what the gap should be on the rings? my HP level i am going for is about 450-500 to the wheels. thanx for any help
Old Jan 22, 2004 | 02:43 AM
maddog20's Avatar
Default Re: CP ring gap question (nextelbuddy)
I 'am hoping around 250ish. 15 pounds on the Greddy kit. I talked to Earl he says bigger on top and CP says bigger on the bottom? They both have good theory behind there thoughts. I don't know I just want to be right.
Old Jan 22, 2004 | 04:49 AM
dennis's Avatar
https://honda-tech.com/zerothread?id=653324
more cp ring info:
https://honda-tech.com/zerothread?id=740618
MastaFlyMason
Engine Machining & Assembly
Dec 14, 2017 04:08 PM
Pullig
Jul 27, 2014 06:34 AM
DulinDragons
Mar 23, 2009 08:41 AM
Muckman
Feb 23, 2007 11:04 PM
B19CivicHB
Jun 19, 2003 04:15 PM
